Mini files
scottie3158
Paul
Holbeach lincs UK
Paul
Holbeach
Do any of you fine folk know where I can get some really thin flat files for filling thin slots. I have a selection of needle files but their cross sections are to thick.
Not cheap Paul, but clockmakers escapement files might do the job. Failing that, drill and piercing saw are probably the way to go. Last option, use an Olfa P cutter to scribe your way through.
I have a couple of 'old' Points files from the bygone days of points ignition in ICE motors. They are about 1 maybe 1.5mm thick, stiff and sharp- only negativ is they are 1cm wide!
These might be of more use to you. also @AlanG who has a comparable problem with cutting slots.
https://www.scalespot.com/reviews/tools/tamiya-engraver/review.htm
I use a metal nail file which is about 0.75mm thick,and I have one that I ground down to about 3mm wide. Worth having a look in superdrug?
scottie,
I use various grades of wet n dry attached to either thin metal sheet cut to size or plasticard with double sided tape to get into the crevices others cannot reach. Obviously you will not be putting too much preasure on the sanding so this might help.
Mike.
Paul, Ultimate Modelling Products do customisable cut to shape sanding pads, they are about a mil thick.
