OK, it’s taken a bit longer than originally envisioned, but then, that’s always the case for me
With the CDL being just about done, I’ve started on the bridge for the AVRE.
As shown in
the instructions (which I posted to Scalemates), in step 47 on page 22, the basic girder is two side pieces joined by zigzagging parts top and bottom. Here is one side piece and both of the zigzags, as well as the narrow end and the middle plate:
Yep, this is four parts, and fit is rather good, as I would expect from AFV Club. A minor difficulty is taking the sides off the sprue, because this is how they are attached:
The gates are very wide, but need to be trimmed against the parts. I ended up snipping through them further away from the parts, where the sprue is still round, and sawing through the flat, wide gates I circled in the photo above before cutting and filing them down to the actual part.
Next, adding the other side and the end piece on the thick end:
This is slightly tricky because you need to ensure the zigzags go inside the side plate, but it’s not actually hard to get right. Just keep checking that things are square, though.
Note that the two side pieces, U7 and U13 are not identical! They look like they are, but their zigzagging struts go the other way. If you take all the pieces for all the sides off the sprues, don’t mix them up, or you may have the struts going the wrong way on some of the girders.
After that, some crosspieces need to be put in to connect the two sides, and a piece added to the narrow end:
You then “need” to build the other three before you can continue adding parts, because the narrow ends of the girders need different parts added depending on whether they’re left or right and at the tank end or the far end. Sure, you could do that first and then add the girders together to make a bridge, but that will mean paying much more attention to which one goes where. So, on to the other girders first!
For comparison, this is what you get in the
International Models Asia conversion set (now discontinued, it seems) for making these same girders (this is for four, BTW, not just one):
Lasercut sides and a lot of L-angle strip.
And after having pictured yourself not really wanting to build that and getting it all square, imagine Mike not even having had those side pieces (and lasercut decks plus resin other bits) but having to make
everything himself …
