You really are having fun with this aren’t you Dave
fun and exasperation! Bizarrely, the thing I thought I would have no trouble with is the CAD side of things - I'd been so used to using one particular system that changing to another is proving difficult - maybe the old grey cells are digging in their feet and refusing to learn yet another programme! Luckiily I've found loads of things from the 'net that I can print!You really are having fun with this aren’t you Dave![]()
You’ll get there Dave. I wouldn’t know where to start……..fun and exasperation! Bizarrely, the thing I thought I would have no trouble with is the CAD side of things - I'd been so used to using one particular system that changing to another is proving difficult - maybe the old grey cells are digging in their feet and refusing to learn yet another programme! Luckiily I've found loads of things from the 'net that I can print!
Nah - the build plate isn't large enough!!! :hungry:I won't be long before you'll be making dinner with your printer Dave.
https://www.theguardian.com/technol...print-it-the-3d-culinary-revolution-is-coming
Sounds good to me Dave.I'm going to start a new thread in the 'warships under construction' section before going any further.....................
Gary,Dave may be of interest , some settings to alter
One of the limitations of 3D printing is the build plate size, whether SLA or FDM. ( I'm talking about hobbyist machines, not commercial ). You have to either scale down a print, so it fits, or chop it up into sections. I found a model that really attracts me on Thingiverse by user PC_Model_Yard.
Jauréguiberry - French Battleship, commissioned 1897 - one of the really quirky French designs!
The model is scaled to 1/700, but that's too small for my taste, so I scaled it up to 1/350. Of course, that meant it wouldn't fit on the printer build plate. I had to cut it into 2 sections. It did take me quite a while to work out how the operation worked on the slicer software, but eventually I managed it. Printing time is predicted to be about 6 hours a section........................this will now go in the queue to be printed!
Great progress Dave.had to cut it into sections to fit the build plate.
Trying to print parts in different orientations, to reduce the supports, or at least minimise the contacts is part of the learning curve - especially on the smaller bits - the larger parts, OK, because of their fewer number, I can live with that.Great progress Dave.
Now you can cut the files up hopefully soon you can get to removing the finer details to print in different orientations to reduce the need for supports and and get even better results.
For instance on your USS Missouri I would have removed the decks and printed them flat, and printed the hull sections on end and empty of support. They would be much lighter and need much less reinforcement to hold them together
My reason for reducing support is build time rather than cost,and in the case of the the ship , total weight versus strength of bond.Trying to print parts in different orientations, to reduce the supports, or at least minimise the contacts is part of the learning curve - especially on the smaller bits - the larger parts, OK, because of their fewer number, I can live with that.
Is the usage of resin comparable to that of filament? That is for a given size of model, would the price be similar? In a commercial environment, I can understand the need to reduce printing times & material costs, but as a hobbyist just dabbling with PLA at the moment, it's not a major priority!
