Thanks AndyGreat building work John, looks really good.
Andy.
Thank you Wabble .Regarding the doors, if you look closely at the photo it is held up by rollers behind the strip attached to the door. The long bar running above the doorway probably has a lip to prevent the roller from slipping off. An angled photo should reveal that.
Wabble
Cheers Neil , still learning !Wow, just wow!
It sure is Andy, got it from Evil Bay, a seller called mtg-terrain £13.26 for 3 sheets 300x200mm x 10mm thick . Pleased with it .HTH.What type of foam is that John? XPS?
Looks so much more realistic with the joints cut deep like that. A lot better than I could manage with foamcore board.
Hi Fernando thanks , good to see you back on the forum buddy .Hi John, first thing I see since a long time when I entered the site another neat looking dio in the works from you:smiling4::thumb2:
Hope your ribs are fine again
Fernando
Cheers Andrew .Simply outstanding already John.
Very well done indeed!
ATB.
Ha, not quite a sling Rick, still trying to imagine how you would manage to do that ? :smiling2:. Cheers , pleased with it so far .OK JR....if you do this well with yer ribs in a sling, I don't think the competition has a prayer!.......keep it coming Sir, you are on your way to creating another "Show Stopper"!! :thumb2: :thumb2:
View attachment 478112Check with Matron.......I'm sure she will be able to ummmm, help you out with that !! :tongue-out3: :tongue-out2: :tongue-out:Thanks Andy
Thank you Wabble .
As much as I like the foam board your right in the fact that you can't seem to get a such a deep joint . Might have a look at doing it on a 10 mm thick section of the Kappa Line, but the foam it's different in its make up .
Ribs are getting better thank you , still painful on the left side . This is what happens when you forget how old you are !
Cheers Andrew .
Thanks John, I've ordered their mixture pack :thumb2:It sure is Andy, got it from Evil Bay, a seller called mtg-terrain ~
"Are you serious "Check with Matron.......I'm sure she will be able to ummmm, help you out with that !! :tongue-out3: :tongue-out2: :tongue-out:![]()
Great Andy, I'm sure you will have some better results with it. Let us know .Thanks John, I've ordered their mixture pack :thumb2:
Thanks Jim, to me this is the best part.I've said it before John but you are really good at this stuff. Outstanding.
Indeed Rick, good point ,luckily it's not in direct line of fire from the heater so should be ok .:thumb2:Sounds like good progress JR....careful on the drying temp for the wallboard filler....too high and it will crack.![]()
