That is the key!!!The best one is the one you can get easily.
Milliput. It doesn’t matter what you want to do with it, it’s crap that’s hard to mix and goes off within a few years, making it even harder to mix. The only one that I found sort of usable was the “superfine white” variety, but mixing white and off-white correctly is a challenge in itself.are there any I should stay clear of?
Second that!Failing that, the best acrylic putty is Perfect Plastic Putty.
If big gaps appear or I create then I may resort to buying an air rifle!!! (That or give it to SWIMBO - she can destroy anything, the reason I gave up the first time!!! She hasn't improved her dusting skills since then!!):unamused:Perhaps unsurprisingly I use a few car body products for big gaps. A spoonful from a tin at work lasts forever at our scale. Being 2 part chemically cured they never sink either.
My industry is fast moving into UV cured products for speed & energy saving so I tried out my Colad UV putty on a few bits recently. Slap it in thick, a few seconds with a UV lamp and it's ready to sand. Probably a bit hard for our work but could be great for filling large gaps very quickly before a final skim with something easier to sand. The curing lamps are a bit spendy though! I have a couple of small Unilite ones that do the job but my "big boy" costs £1500 :surprised:
Back in the real world of modelling products I like Mr White Putty in a tube for thicker stuff then Mr Dissolved Putty for thin or shallow areas. Being a thick liquid it seeps into small cracks and levels out minor imperfections well. They both tend to bite into the plastic better than waterbased acrylic fillers, so feather out more easily.
Nice to hear. I have a couple of joins on my Sea King which will benefit from a wee bit of filling, albeit not too much thankfully.I tried PPP (irst time using putty) to join the gaps between the wings to the fuselage and seems fine so far.
I remember my wife picking up a WIP 1/72 wingy thing for a closer look and promptly dropping it on the kitchen floor. "It might be good love, but it can't actually fly!" :smiling5:If big gaps appear or I create then I may resort to buying an air rifle!!! (That or give it to SWIMBO - she can destroy anything, the reason I gave up the first time!!! She hasn't improved her dusting skills since then!!):unamused:
