Thanks chaps. I'm more than happy with the result so far and I'm chuffed you folks approve too! :thumb2:
453, quite right. I don't worry about light brush marks as they can be part of the weathering process, but at the same time I do like to try and avoid them.
On our pond I've rigged up an overflow system out of plastic overflow pipe. I siliconed it to the stonework at a suitable height and hid it in the ground. The excess water now runs out into the lane.
Could you not make a basic soak-away?
Graeme. Thanks for the question. I've read the book and seen the film. Both very good. I've reasoned that if the collision did actually happen and was not a result of friendly fire, then the impact speed could have been in excess of 400mph. So I reckon the damage would be severe and not as suggested in the film and book just "Sliced off"
Also, on the model, the two oxygen cylinders are in the same area as the antenna, so if the impact was there, I would suspect the cylinders would have exploded.
Either way, I'll try and model the impact somewhere just aft of the antenna, mid way towards the tail section and just hope no one suggests it was further this way or that along the fuselage.......
Ron
