YES Ian the ones that dont blow the fuse are johnsons motors right up towards the rudder an the ones that blow the fuse are the graupner 600 motors but i think i will replace the johnsons as i dont think they are powerfull enough to power tigers wheight thats why im goin to get new 4 x new more powerfull motors if you get my meaningSo a 9.6v motor on a 12v battery..... Could that be the issue?
Looking at the motors you have given the info on I Would say that they are under rated for the system. As it says on the box you posted nominal 8.4v operating range 6 and 9.6v If you are feeding them 12v they are not going to play nice but you know that.
I would suggest a look at these from Krick. Max POWER 500.
https://www.krickshop.de/MAX-Power-...ick_e&SessionId=&a=article&ProdNr=42246&p=354
Pretty sure you can find them in the UK as well
I did not know that it was two motors per fuse and only two of the motors that are blowing fuses. (just guessing on the info given). Are the motors different form the ones that do not blow the fuse?
chrisb
