Calvados is just Cider with the water removed...Old trick was to make Cider AKA scrumpy, put it in a barrel outside in the winter. The water would freeze and the much stronger booze could be found un-frozen in the center.... And yes it works. Maybe not as good as the expensive stuff but if you have a ton of apples in the garden...Calvados is the elixir of life!
