Steve's 1/32 Special Hobby P-39
stona
I thought I'd better start a thread to encourage me to get on with this one!
I seem to have a big pile of nice looking, if slightly hard/brittle plastic:
I have bought some masks and also have the kit decals to have a go at:
Of course there's some of this Bl*$dy stuff:
And finally this chap here, from the spares. He must be Russian because that's what I wrote on the bag!
What could possibly go wrong?
Looks good with your extras there Steve :thumb2: ,
If he doesn't turn out to be Russian,just carry on anyway.... with a scalpel and the correct colours,he soon will be!!;)
Well Steve, you have actually got further than I have. I had to get my Raiden over the finish line and post the final pictures.
Have you used Montex masks in the past? I know they're vinyl rather than Kabuki and I know some people aren't fan of vinyl masks.
I have used both types at least at 1/72 and probably found kabuki slightly better but that may be due to the scale.
Looking forward to seeing you work your usual magic.
ATB
I've used vinyl masks a fair bit in the past. I do quite like the vinyl masks in a larger scale, but I can see why they might be tricky at 1/72.
I used to buy generic masks or sets of masks from Maketar, but I think they have ceased trading. There's been a rather ominous message on their site for months now:
They clearly haven't come back soon!
I've only used Montex once before. The canopy masks didn't fit very well, so I ended up cutting them just as I would had I not had any pre-cut masks. The others were fine.
Some nice added extras you’ve got there Steve, looking forward to seeing it all come together :thumb2:
I’ve used 1/72 vinyl masks in the past and they were ok but if all else fails they are useful templates for creating Tamiya tape replacements :smiling5:
Geoff.
Nice choice steve , did special hobby supply a tailored nose weight ?
Thanks Steve. The problem I found least at 1/72 was getting them to stay bent around tight curves on smaller masks.
Nope!
The instructions don't suggest any weight either, which seems odd for a model on a tricycle undercarriage.
I'm almost certainly going to pose this one in flight, so the necessity or otherwise of weight in the nose will remain a mystery :)
Yes, I can imagine that being an issue. In larger scales they are almost invariably on fairly gentle curves or flat surfaces which don't pose the same challenge.
I've been a bit busy of late, a bit of a contradiction for someone who is trying to cut back on work and at least semi-retire, but there you go!
I have made a start and am still planning to get this done in time for the GB. There's not much to show, just this, though I have made and fitted undercarriage doors in the lower wings. As is often the case, those in the kit are not made to be fitted 'shut'.
To be honest, the cockpit is pretty basic. There are no instrument decals in the kit, so I will raid my spares to find some that look the part, even if not exactly accurate.
Anyway, this is now officially in progress.
I've had a good go the last couple of days
That's it for a few days, I might get another chance over next weekend.
Looking good Steve. I like the labelling. I could probably benefit from being more orderly like that.
Missed the start but just caught up. Looks to have decent detail although the cockpit is slightly lacking. Surprised there are no instrument decals, especially at this larger scale, but I doubt whether very much will be seen anyhow. You're off to a good start, all nice and neat, and the pilot certainly looks the part.
Someone else mentioned that very same issue a while ago. I wonder why that is? :thinking:
Yep, some of those bits could be fitted upside down on the wrong side....ask me how I know :)
I stuck the wings together and joined the fuselage halves. It seemed sensible to see how those two would go together.
Overall the fit is not bad, it's a kit originally produced in 2007, though there are some issues at the front underneath, mainly due to some 'interesting' kit engineering. It's all doable though.
It took me a moment. At first glance I thought it was masking for some crazy scheme, then I read the text!
