Hi Barry, could you explain why your exhaust outlet is facing a blank wall. Normal SOP would have the exhaust facing a window or through a vent that exits out to the outdoors.Could someone with experience please confirm that a recirculating Benchvent BV300S spray booth should NOT vent any acrylic airbrushed paint out the back onto, for example, a bright white wall?
Many thanks,
Barry
Joe with the kind of spraying we do, filtration won't cut it. The fumes will still circulate unless there's a solvent that can kill the odor and chemicals. Must be a wonderful product.Hi Barry. I've no experience with that spray booth. I looked it up, I presume that the BV300S is not externally ducted, but uses a re-circulatory method?
Sounds like a filtration issue to me. No paint particles should ever get through the filtration system, although you will get solvent fumes from the exhaust. It may be worth checking the filter(s) are installed correctly, and that you have an appropriate filter fitted (I see there are many options available depending on your use).
Hope you get a satisfactory resolution to the spray booth issue.
It looks like that particular booth is for a room where there is no opportunity to externally vent the exhaust (which is the best option). Presumable Barry is using water based acrylic paint. You would expect fumes (hence water based non-toxic acrylic paint), but never paint particles, to make it through the filters to such an extent that they spray his walls.Joe with the kind of spraying we do, filtration won't cut it. The fumes will still circulate unless there's a solvent that can kill the odor and chemicals. Must be a wonderful product.
Wabble
Hi Tim,Not quite sure of your question here? Are you thinking of buying one and want to know if it will do this, or do you have one that is doing this and wonder why? l’ve not used one of these. Seen one in use though, and do have extensive experience in using bio and chemical containment systems, so understand how all this works. I’ll therefore try to answer you.
For the former, Andy’s suggestion is a cheap sensible option if this prospect worries you. I have a much cheaper spray booth that simply uses a push in particulate filter and this doesn’t happen to me. I’ve never been able to vent mine directly out of the window, so just allow it to vent into the room with the window open. I do wear a good mask though.
For the latter, breakthrough could be due to poorly fitted filters, though this looks a high quality unit so that shouldn’t be the case, or filter overload.
Overload can happen if the filter is at the end of its natural life or if the particulate challenge is too high (ie too much going through at once).
A HEPA filter like this isn’t a tea strainer mesh type filter. The best way to visualise it is by thinking of the filter matrix as a very deep maze that the particles have to negotiate to get out. The constant twists and turn mean the particles lose energy and momentum and eventually get stuck in corners or blind alleys in the maze, so can’t get through.
These HEPA type filters do eventually allow break through though. As the pockets and blind alleys load up with old particles, the new particles can get to the end of the maze. However, if this happens you would notice a marked drop in the filter face airflow velocity by that point.
I would say the primary design ethos of this booth is to reduce or eliminate overspray, so personally would wear appropriate PPE while using it for anything except water based acrylics. If you really want to eliminate all particles and solvents you would need to look at professional kit, designed for continuous use, which comes with a far larger price tag.
This one looks good to me for hobby use though.
The point is that Benchvent describe this as a Glue booth, not an airbrush spray booth. I am wondering if the difference might be pigment size, spray paint may have a smaller particle than glue particles, hence some paint particulates getting thought. Also, of course, without extracting to the outside you could well get odour and particulates in your room. It’s not necessarily from overspray. Even with my bv300S extracting booth, if I don’t change the filter regularly, when I do a long spraying session it can smell out the room and, at times look ‘fuggy’ with particulates in the air. Frequent filter changes cure this though.Hello Barry,
You should not be getting any over spray. All the 'dust' should be going through the filter(s), I would check to make sure they are fitted correctly and snug. And obviously the exhaust pipe has to go through the window (not litteraly).
I bought a similar cheapie design from Azon, and after inspection decided to keep the fan, exhaust pipe, turntable, filters and instructions and built my own from mdf using the assembly instructions as a guide.
And as the design of these spray booths are pretty much the same the problem has got to be a simple one to fix. I would start with the filters and then go to the exhaust fan and finally check the hose for any split(s) especially around the area you describe.
In the description it's also suitable for airbrushing.The point is that Benchvent describe this as a Glue booth, not an airbrush spray booth. I am wondering if the difference might be pigment size, spray paint may have a smaller particle than glue particles, hence some paint particulates getting thought. Also, of course, without extracting to the outside you could well get odour and particulates in your room. It’s not necessarily from overspray. Even with my bv300S extracting booth, if I don’t change the filter regularly, when I do a long spraying session it can smell out the room and, at times look ‘fuggy’ with particulates in the air. Frequent filter changes cure this though.
