Pledge Polish
I have to admit I haven't used it for a long while Andrew. The bottle is nearly empty and I discovered AK matt varnish which I really like for both brush & airbrush.
I seem to remember it was quite matt though, and went through the airbrush okay with a little water to thin it. If you bumped up the pressure with a larger needle I'm sure it would spray neat.
What’s your go to clear coat Andy?
For gloss it's Mr Color GX-100 lacquer, but the ones I use most are the VMS HD acrylic varnishes. I use the satin a lot, and once I finish my bottle of AK matt I'll probably replace it with the VMS.
Mick
I guess this is not much help to you, since I am a part of a "foreign field", but this is what I use on my figures.
Hello Mick,
Pledge on Azon dries clear. It used to be Johnsons Kleer
Pledge floor gloss currently unavailable.
Mick
Where do you get your Pledge polish from John - Canadian Tire or at a regular supermarket?
