Heat source for annealing
BattleshipBob
Bob
Cardiff
Morning rabble
At the moment I have stopped building and as my mojo is back ( at last) I am focusing on the horrors of good old PE. With KGV having a shed load, it's a ideal time to both ruin it further but excellent practice!
Now the question ( you know it was coming).
I need to anneal some parts, splinter shields etc but only have a ciggy lighter which I use to burn off pe to use as a heat source. What is best chaps! Was thinking of those hand held butane lighters??
Not a problem, you cannot control the lighter and the etch at the same time - thin etch will get burnt away and your fingers will get hot through heat transfer.
For a quick wave over of etch just to get it a little annealed I use a wax candle, stand it on an old lid by dripping some of the liquid wax onto the lid and then straight away putting the base of the candle onto the soft wax.
Etch - with the candle lit (you would be surprised!!!) take the etch and hold it in a pair of tweezers or small pliers and move the etch back and forth over the flame - you do not need to be in the flame start off about 15mm above and work down moving from side to side and you will see the colour of the brass change. It does not need to glow red, but a lightish red brown will be enough of a colour change.
First try with a thin bit of the fret, not the edge of the frame as this is actually thicker, but one of the thinner runners inside the frame.
If a part becomes warped then lay it flat and use a roller to go over it with a little pressure and then turn it over as it will follow the roller and do the same on the other side.
A quick light sanding will give you a surface to c/a the parts together.
Mike.
Follow on Q.
Would Mikes procedure work both on brass and steel etch?
2. Would you realistically anneal ‘all’ etch?
TIA
Doug
Follow on Q.
TIA
Doug
The 'steel' etch can be a pig, but the same method can be used, but may take a little longer... heat.
"2" No! It all depends on the part - for example a tube comes flat and needs rolling - anneal. A box comes flat - bend as is.
Mike
Mike
Superb, thank you Mike. A star as always. :thumb2:
I use a gas cooker lighter - Poundshop - Amazon...................
Have a big gas capacity, and easy to control - can give a large flame!
Mike.
Excellent, many thanks Mike.
Sound advice !!
Cheers Dave, will nick sorry borrow a candle and give it a go. My dear mum always had them, just incase!
Ideal if there's a power cut as well.
I have a lighter or two which I use for that. I find candles far to sooty, but they are probably cheap ones!
Dont use your good tweezers to hold the parts with. you will knacker the tips and they will bend just as easy as a lead pipe in a furnace.
The cheap reverse action tweezers with fibre grips are probably best for this.
Morning Ian and ta very much. Being a lazy bugger with a cuppa in bed!!
