Colin M’s Eduard’s 1:48 Tempest Mk V
colin m
Staff member
Colin
Stafford, UK
22nd May, I said I would enter the GB with this. Ok, a little bit late to the party, but here we go.
The box.
The contents
The Profipack comes with everything except paint, glue and time.
So, a wet Sunday, let’s get going.
If I ever build a 1/48 airplane model in my life, I'll build an Eduard Profi Pack!
I'll be so bold as to sit next to Paul.
They really are good. Eduard detail is top notch, but then they chuck a mask set in and a bit of photo etch. The prices are good as well.
I would just add a caveat to that…..later ones are better than the early ones. The Zero I built for the Japanese GB was superb though. Probably the best aircraft kit I’ve ever built.
Joining the party! I have this in the stash.
I'll second what Tim said. I built their Yak 3 last autumn and had a few issues, especially with the the etch IP panel not fitting in the space allocated to it at all.
Good luck Colin!
ATB
That’s got me thinking. I’ve been building Eduard’s for years, but only Profipacks, I wonder if the Profipacks are all newer moulds ? It makes sense in a way.
We’re off, I did wonder where the tiny bits of plastic came from I found floating around. Now I know !
A quick repair needed, I think I’ll get away with this.
And this little lot is basically the cockpit waiting for some paint.
The IP is made from 7 different pieces.
Time for a bit is spraying, but daughter No.2, recently returned from Uni, is still asleep. At this time. I mean, how much sleep do 20 something years olds need ?
Nice one Colin, looks like a great kit, and off to a good start.
Hi Colin
I can confirm that NOT all ProfiPacks are newer mouldings. You need to look at Scalemates to what's what.
A number of my Eduards are older mouldings...a couple I think are even from the late 90s. The Yak I built last year was certainly one of the earlier ProfiPacks.
Keep up the good work!
ATB
Looking good, I gave up on my Eduard Tempest so it'll be good to see this one come along!
What put you off Steve ? Why not dig it out and we can build together?
It seems a bit of rain was quite welcome today. Water buts full and cockpit finished.
And the other angle.
All photo etch provided by mr Eduard.
Hi Colin
Interesting, it looks like I have been lucky.
That looking superb Colin. :thumb2:
That's looking great Colin. Almost makes me want to dig mine out of the stash!
That office was great, how on earth you managed the repair , very neat Colin.
Well now, was I saying how great Eduard kits are ?
I don’t know what went wrong here, but the lower wing doesn’t fit.
There seems to be a problem with the air intake assembly fouling the wing. I can’t see what I’ve done wrong as the assembly is quite straightforward. Anyway, a bit of butchery will be needed to get the wing in place.
