20mm Vickers mg team. Geoff’s D Day 80th anniversary GB
Tim Marlow
Tim
Somerset UK
Finished these guys this morning.
Quite fun to do, though a bit fiddly at times. 28mm white metal figures, painted in Vallejo acrylics. Calibration shot in the build blog if you wonder how big they are. Hope they pass muster :thumb2:
They certainly pass muster. As always, when I look at your work, I am in awe of your abilities in painting these tiny figures. I've read your post in Steve's Time or Talent thread and this work reflects your post there.
One little question. As they are a group, a vignette, why are they on separate bases?
Um, 20s or 28s? Just that you've got the former in the build thread (which I assume is correct them being SHQ) and the latter here?
Still admiring the Denisons and overall splendid result either way
Thanks Jim. To answer your question they are not really a vignette, they are a gaming piece. The rules I play list a medium mg team as consisting of four men and a junior leader. The leader is Mr pointy guy. He‘s separate so he can be removed as a casualty (which impacts morale and efficiency). The other two are separate so they can be removed to track crew casualties. The remaining two are based with the weapon because if the crew goes down to one man, with or without the leader, the gun is deemed U/S and the remaining guy is replaced with one of the rifleman casualties.
Well spotted Steve. They are 20mm, so I will ask the mods to correct the headline…..done too many 28s recently so got the header wrong. Glad you like them though :thumb2:
Great work Tim. Those paras look great. Will these be used for gaming or simply for display?
Paul
As good as ever, Tim. I love the basing, with lots of subtle variation. I guess at this size it must be easy to swamp the figures with overscale greenery?
Paul
Hi Paul. They are designed for gaming, as described in my response to Jim above.
