As a little summer project, something I could dip into and out of once in a while as time allowed I built this. The Airfix 1:24 Spitfire Vb. It's apparently well known for a poor fit and needing lots of filler - well, not so. I hardly used any filler in the building of this model. However I did remove quite a few locating pins and fitted many panels individually, if that makes sense. Maybe I should say most panels were adjusted for an individual fit - I've confused myself now.
This is the BBMF Spitfire Vb, but in the giant box are the tropical bits. Well I couldn't help myself, a big tropical Spitfire, it had to be done. The decals are kit decals and some spare ones, lots of artistic license here. And also a pilot. I don't normally do figures (and it shows) but this model needed a pilot.
I did some work correcting the dihedral, although for some reason it was fairly close anyway. Paints are the very nice Ak interactive. Scale effect corrected etc. As is quite typical of my builds, the aircraft is a bit tired. I sprayed aluminium first, dabbed a bit of Maskol stuff on and carried on with the painting, removing the Maskol later.
So here it is, a summers work. I'm actually quite looking forward to the winter, so proper building can resume once more.
Colin M..
Colin M..
