Well ive had a tricky time with the canopies on this little bugger. The canopies are commendably thin and clear but in the case of the main section , a bit too thin!!! The overlapping bit at the rear of the main part is that thin ,I accidentally went through it while cutting the tape masking the windows. I think its a very thin piece of the moulding and anyone considering this kit should bear this in mind when masking or handling these clear parts. The 2 curved rear side windows are a bit troublesome too, they are a great fit but you have to be careful how much canopy glue you use or it will wick underneath and be seen from outside as these have no frame round them. Normally I would have attached these last off but the main canopy overlaps them (the aforementioned thin bits!) so theyve got to be masked and go on now. Anyway the canopies are on and im just in the process of filling the step in front of the windscreen . Apart from the clear parts needing a bit of careful handling ,the rest of the assembly has been great , ive even managed NOT to break off the very fragile guns !
