Right, let the keyhole surgery commence!
I started by gluing the main legs together at the top, let that dry a bit, then glued them to that part 10.
Then stuck the triangular braces to the fuselage sides with blu-tack (alright, white tack) so they could move:
Put a drop of cement on the tips of those and added the main legs:
As you can see, this plane is too small for my assembly jig, so two Tamiya jars and more white tack to the rescue. Let that set for a bit, then cut a bit of sprue, filed a notch in it to fir over the ridge on part 10, and glued it to the back of the engine:
You can just make out another bit of sprue at the top of the gear bay, which I just filed to fit between the top of the wing and 10, dropped in place and dripped some cement on it.
That's it for tonight, I'm going to quit while I'm ahead! The top panel can wait until tomorrow.
Thanks for watching,
