Hi all
So as some of you may have seen
here, I succumbed and bought the AM nose.
It's not that I was completely turned off the idea of doing my own nose but I'd already lost the best part of two weeks to it due the limited bench time I get and so if only for my sanity it will probably be worth it. That may be a bit of a cop-out but I don't want to lose the mojo on the build because of the nose.
I had done two drawings of the possible nose shape, with number 2 being the closest but still not perfect. The AM nose itself is not 100% perfect, although it's nicely done. The Quickboost AM Mk XII nose was a
perfect fit, by contrast this needed a little of filling around the nose.
As you will see from the below pics, there is definite step between the nose I've fitted, compared to Lonesome Polecat's which appears to be a pretty smooth transition. I don't think is a trick of the light or camera no matter how I look at it. However, I've found a clearer picture of of HK428 and there appears to be a definite step unlike the initial picture I found. What's more one site shows Lonesome Polecat staring it is Mk XII......its not!
Oh and most artists' impressions of Mk XIII I have show them with a smoothly transition - but LP is an exception in one case!
In short I give up......and have fitted the AM nose for better or worse! Oh and it also comes with the gun camera and some very thin (too thin)
resin for the wing aerials.
ACW as usual......and I promise to say no more on the nose issue after this post! Promise....I'm getting fed up with it and so you must really be!
ATB
LP's nose.....
HK428....
My efforts on 'DIY nose Mk II'....
The AM conversion kit with nose and gun camera fitted....
