Andy T's Italeri 1/24 "Australian Truck"
Thanks Mick & John. I got a bit more done this afternoon but I'll not spam any more pictures today :smiling5:
Should be a decent bit of progress over the next few days as I'm not working until Wednesday.
Nice idea Ian, I may just take you up on that.
Had a go at the cables / airlines and I'm reasonably happy. At least it's covered the paint blob :smiling5:
Found some coloured wire from an old phone extension cable and wrapped it around a skewer to make it coil
With not many reference photos to go at I did a simulation of the susie bracket. I must have been watching too many videos by Steve Jones as I embellished it with a few rivets
I also made a place to dock the cables when they weren't in use.
After a coat of Alclad chrome they were fitted and the coils attached. The coils are a bit stiff really and don't sit too naturally but I was working with what I had.
Thanks Jack .
Im going to have a go at rewinding them as they've sprung out quite a lot, would have preferred them tighter, but better than nothing :smiling3:
Pity if they have opened up Andy they looked spot on in photos.
That body work paint finish , wow ! :thumb2::thumb2::thumb2::thumb2::thumb2:.
Great work on the Susie's Andy, I'm surprised how they are missing from 1/24 kits as they are quite an integral part of the truck.
Thanks John & Mick.
Thankfully they aren't glued into place, just a push fit, so I can have a go at winding them around something tighter to allow for the spring back. I may even try the hot/cold water trick to allow the rather thick insulation to relax a bit.
I found some Mr Muscle oven cleaner under the sink. After submitting the relevant permission forms I was allowed to borrow it, and it has kinda worked.
9 hours and many repeat applications and it's starting to strip the chrome. I'm beginning to wish I hadn't bothered and just smothered any ugly seam lines in mud afterwards! :smiling5:
I've used thick bleach to strip chrome from Italeri kits. Worked a treat and only took minutes - you could see the chrome dissolving.
Thanks Allen but I think you are mistaken. You may drive on the right side of the road, but we drive on the correct one :smiling5:
The blob
The interior painting didn't go so well as I'm still a bit rubbish at brushing larger areas, but with his chunky fluffy blanky the driver should have a comfy nights sleep.
Yes it's over scale, but once the sleeper is closed up and attached to the cab you'll struggle to even see it.
Don't worry about the blanket being overscale, I used to have a king size 13.5tog quilt folded in half on the bunk, three duck down pillows and then another 17tog quilt on top and I would not get out of bed untill the night heater had warmed the cab and the coffee had brewed....
Great build by the way.
Thanks Mike, sounds like my kind of bedding!
I've not been looking forward to the fuel tanks so made them today's mission. I reckon they'd be fiddly enough OOB but with me wanting blue tanks with chrome straps & steps it made it that bit harder.
I'd pre-chromed the brackets & steps in case there were areas I couldn't reach later, so after scraping paint from all the mating surfaces I wrestled this lot into position. With a lack of really positive mounting point and several small pieces to line up in one go it was like wrestling an octopus but I got there eventually.
I then masked up the blue, which in itself was a bit of a task
A coat of gloss black was followed after a time by Alclad chrome
Then I carefully peeled off the tape
The came fitting. Trying to line up 2 tanks and the flimsy toolbox step on each side was again a challenge but it's all close enough if you squint a bit.
The air filter stacks and screen visor were added as well whilst other stuff was drying.
Really good Andy.
You certainly have patience and a lot of skill.
Thanks all.
Well, much like a sky diver may experience ground rush, all of a sudden this is almost complete :flushed:
I kept adding bits here & there and suddenly I ran out of parts! Almost lol
I found the rear light units still on a sprue I'd put for stripping & recycling, so they've had a drop of paint and I'll put the licence plate decals on tomorrow. I've decided against any weathering. In the future if I have the money & space to add trailers I'll do it then.
