Andy's 1/48 Spitfire Mk1a
Andy T
Sheffield
This is the largest of the three that I'll be attempting for this GB. A 1/32 would be a stretch within the time frame, even for me, but maybe later.
This is the scheme I'll be using for all 3 aircraft
Here are the sprue shots. Being the profipack it has some extra goodies, and plenty of spare canopies if I fluff one up!
That looks like a beautiful kit andy . If its anything like the 1/72 eduard spit i did a bit back it will be great . I reckon the fit and finish on these is on a par with the best Tamiya stuff and detail is probably better , looking forward to this one .
Thanks for popping in chaps.
I made a start on this today, building up the cockpit sides and whatever you call that bulkhead behind the seat.
I lost the very first piece of PE for the tanks which doesn't bode well 😂, so replaced it with some copper wire. As you see here though, it won't stay in place. My usual CA glue nemesis is back. I tried 3 different glues, with or without activator, applying glue to the plastic, the copper, or both, and still no luck.
It's staying off for now 😁
What a wonderfully well engineered kit!
Don't get me wrong, there are some small and fiddly pieces, but everything fits together perfectly and logically.
Starting with the seat, the flare rack (I think) is moulded into the plastic but it can be cut off and replaced with a PE version. Following old advice from Rivet Jones I made sure I could make the metal version before hacking the plastic one off 😂
Having managed that I put the control stick together from 3 plastic pieces and a tiny bit of etch, just visible at the top. I also added the seat sides and armour plate behind, of which there's a plastic version or the PE one seen here.
Several parts made up the cockpit floor and a number were added to the cockpit sides. There are still a few to add but they are either different colours, or pre-painted etch, so I figured it was time to splash some paint on.
As a side note there are 6 door options and of course I fitted the wrong one and had to change it part way through painting 🙃
Next up is the detail painting, adding the remaining parts, then fitting it all together.
I'm still working on the office. There are several options for the IP but I'm using the painted etch, so picked the appropriate flat one.
Once the etch is layered on top and the gun sight added, it's very effective
Looking good Andy, looking forward to see those 3 scales together (y) Have fun
Thanks everyone, your comments are much appreciated.
I'm sulking at the moment. It was going well then I had a nightmare with the harnesses. Long story short several bits dropped off while trying to fit them, and despite many attempts they just won't stick down.
In the end I used loctite super attak, held them in place for 4 minutes and 5 seconds (the duration of ABBA - Take a Chance on Me, playing on the radio) and they still popped right off 😂
I'm walking away for now as I'm tempted to close it up as it is lol
Cockpit is looking excellent andy , ive had the same problem regarding sticking the belts to the seat , what ive started doing is rubbing the back of the etch with a sanding stick to give it some key . It helps but sometimes they still spring back up .
Thanks for the pep talk Tony, I'm feeling better about it this morning 🙂
The belts still won't stick down but I've bent them so they naturally sit in roughly the right place.
Some matt varnish will hide the errant superglue.
Looking really good Andy. Glad you are enjoying it. I have found recent Eduard kits as good as any I’ve built. I rated the Zero I made last year as the best kit I’ve ever built. You’ll love the decals…..they are as good as anyone’s. It’s worth finding out about stripping them as well, it gets rid of the carrier film.
I’ve had the same issue with Eduard PE and superglue, by the way. It’s seems the printed surface doesn’t like CA. I’ve even had the printed surface lift off when glued…. I’ve gone over to using formula 560 canopy glue for these bits with some success if you are interested.
