Battle of Coral Sea Yorktown CV-5
Wow, you certainly put your heart into these builds Greg. Great detail,as always .
Thank you all for comments and support...
So....here is today's update on the diorama Battle of Coral Sea...added the railings and some ropes... .enjoy20211017_191623.jpg20211017_191709.jpg20211017_184133.jpg
That’s lifting it even higher. It’s going to be stratospheric when you finally get to the end :thumb2:
A railing we will go, a railing we will go, hey ho the day rio, a railing we will go...
After the portholes its the railings that can make you go daft. We're all here if you need someone to talk to...nah you're doing fine...too fine I might add. :smiling2:
Greg
There's the 'modelling' I do and then there's this..... Brilliant already and yet you've barely started. As Tim said, I can only imagine what it might look once finished.
ATB.
BRILLIANT WORK Greg an are all the p/e bits just laid on ? so you can paint the deck ? keep goin as im enjoyin this carrier build as i built a big uss nimitz carrier build
so got a vested instrest in your carrier
chris
Thank u all for your constant support ...
So here it is...Here is today's update on the diorama battle of Coral Sea...made some adds and find out that there are some corrections to do...did some dry fitting and some doors will be added...enjoy...
Dear all...as usual thanks for your kind comments and support....
Here is just a quick update..adding of watertight doors and box...tomorrow hopefully placing of the remaing doors portholes (arrrgh they are back) and base of the mast...enjoy
