I use a DVD disc to cut tape & also PE frets.
Does not slip (PE) plus it is kind to Mortons.
Also use the American Razor which is much finer than a Morton blade.
Also use the American Razor for cutting PE from the fret. So fine that
in most cases you do not have to file off that rough bit. Cheap as chips
& you have two edges on each blade.
PS. Good idea to just tape one end temporarily. Saves on blood. :smiling6:
Another thing that I have picked up with in the disaster experience area.
Keep the amount of tape in contact with paint to a minimum. Just use
enough thickness of tape to mask then use tracing paper or similar to
stick over the masking tape. Then there is the minimum likelihood of
paint stripping .
B & Q market a very thin foam roll which is used under hard flooring.
Perfect for filling in masked areas. Easily cut or torn paint proof & also
forms easily to rounded surfaces. From memory about £10 per roll.
https://www.ebay.co.uk/itm/American...058006&hash=item3cf5687844:g:Y-AAAOSwSlBY3SZw
