Dave Ward's Eduard 1/48 SSW D.III - Brad9826's WWI Memorial GB
Engine ready to fit, and the first coat of Vallejo Scarlet applied to the front fuselage
For those who are not familiar with this................
Unlike other decal solutions, this is a single part, as I have said, it is a bit fierce, and you need to be careful!
The outer struts have decals applied to the inner & outer faces - with these, I just placed the decal on the surface no rubbing with cotton buds etc, and applied a thin(ish) coat of DecafFixView attachment 310755
The solution hasn't quite dried yet, but it has sucked the decal down around the struts. I'll leave it overnight to really dry.
Boring!!!! This is the result of adding 50+ rib tape decals............................
I'll apply a satin varnish, to seal everything in. It's a real slog, adding these decals - luckily there are a few spare...............
Going great gun's Dave. Decals are well popping, .. In what way is decalfix fierce Dave, as I have a bottle, but not used it yet? Cheers bud.
Brad,
DecalFix will find any flaws in decals - I've had older decals disintegrate, and if you get a fold in a decal, you're in trouble. It's not like other decal solutions, you have to get the positioning pretty close first time, as moving the decal is not easy. Having said that it does suck the decal down onto the surface very well.View attachment 310862
Humbrol direct you to soak the decal in neat DecalFix. - I dilute the solution 70% water 30% DecalFix, and only use neat Decalfix to brush the location, and after placing. Avoid touching the decal with fingers, as it seems to stick to fingers pretty well!
Thanks Dave, all noted.. If I ever get to a stage of applying decals..:thumb2:
Wings satin coated - when fully dried, I'll clear the holes for the struts and the rigging - seat and simple belts added.View attachment 310972
I've joined the fuselage, and primed...............View attachment 310971
I think it's going to come together pretty quickly, now.
Whilst I was applying the rib tapes, I was thinking about my next build - and I think I'm going to have a crack at this-View attachment 310973
It's being calling me for a while now! Not plain green, but a camo finish.
I had the same problems with Decalfix - decals stuck to the first surface they touched, usually fingers. The ones I managed to get onto the model refused to move to the right place.
Hiya
I use Microsol and microset (which is the one Decalfix sounds like). I may have it wrong, and I may have misunderstood what you have said, but I though you were supposed to brush it on the surface after the decal has been positioned, not use it as the decal is being placed? It softens the decal to an extreme allowing it to conform to the surface, so would make them really difficult to handle?
Tim
Humbrol have a video showing decals being soaked in Decalfix to remove them from the backing paper.
Funny that, microset states not to touch the decal after application until the decal has dried out again....whichever works I suppose...
Tim
Here's a link to the YouTube video * Humbrol DecalFix* on how they recommend how it should be applied. It being a single part solution, it is used differently to the 2 part MicroSol/Set
Bottom wing and fuselage offered up for the first time
It makes you wonder why, after going to the trouble of printing the complex lozenge camouflage canvas, the planes were then painted in such bright colours? A complete contrast to the drab RFC/RAF PC10!
The engine and cowling added - a little jiggling needed to get things to fit, and the machine guns added.
Now begins the tricky bit - top wing, and the centre section rigging, this is not something you can rush, you have to have steady hands, so no double espresso for me today!
Looking very good Dave, and good luck with the top wing fitting.
Hello Dave,
I've built a couple of these Eduard kits and really like them. Although to be honest, with all these decals, I might avoid this one. But hat's off to you for tackling it. It's certainly turning into quite a colourful beast.
Top Wing added - all struts present and correct
View attachment 311137View attachment 311138
Sadly, my rigging on the centre section went awry, so I'll have to revisit that - but tomorrow, when my hands will be steadier........
Wing rigging added - !!!! PHEW !!!! - I used 0.1mm elastic line ( like EZ-Line ). I found out that it didn't like my Loctite CA - it didn't 'grab', so I had to revert to my backup el-cheapo unbranded...................
View attachment 311365View attachment 311366
At the moment they are natural white colur, but I'll use Vallejo Game Ink to give a dark grey finish. All the rigging holes in the wings will be made good - the lozenge decals will cover up a lot! A lot of squinting, holding my breath and blasphemy has got me over this hurdle! :smiling6:
Nice work with the rigging Dave, I've got mine to look forward too
