Been looking a the above, has anyone a brand that they can recommend. Seen that many on Evil bay, several clear types and some auto shop ones.
Thanks .
Thanks .
Hi Peter, for Friul tracks during assembly..3M tapes are usually good, as are Tesa. What are you planning to use it for John?
Cheers Tim .Can’t help with a make John, I’ve had mine about twenty years ...... good hint though. Stick a bit onto a flat scrap of wood and don’t remove the waxy cover. Add a puddle of superglue on top and it will stay useable for ages.
Thanks Andy, well it's only going to be about every 2 /3 months if I do Friul tracks so might as well get a cheap one.3M refix tape ( 06506) is the daddy if you're after a really thin one.
But if I'm honest, the £1 roll I got from Hobbycraft is very nearly as good, and it's significantly cheaper. I just use whichever one falls into my hand first.
