Geoffs Airfix 1/72 Bristol Blenheim Mk.IVf -Paint it Black GB
Geoffers
Geoff
Shropshire
Thank Ian for running the GB, I’ve enjoyed taking part 👏
My build is now finished, it represents an aircraft of No.68 Squadron RAF flown by W/Cdr Max Aitken from RAF High Ercall, Shropshire during April 1941.
Max Aitken was the son of Lord Beaverbrook, who if you weren’t aware was the owner of The Daily Express and became Churchills Minister of Aircraft Production during the early part of WW2.
Max survived the war as a fighter ace with 6.5 kills and ended the war as the wing leader of the Banff strike wing (Coastal Command).
Click image for larger version  Name:	IMG_4698.jpg Views:	0 Size:	104.3 KB ID:	1265012
Anyway the kit itself went together well, I was a bit dubious about the multi part cockpit but it went together reasonably well with a bit of care, most of the joins thankfully being on areas that were later painted.
I used dot filter technique with oils to weather it just to add some variation to the black (dark grey 😊) surface which looks good but doesn’t show up too well in the photos.
So after all the waffle here she is 😀
Click image for larger version  Name:	IMG_4685.jpg Views:	0 Size:	366.5 KB ID:	1265018 Click image for larger version  Name:	IMG_4685.jpg Views:	0 Size:	366.5 KB ID:	1265018 Click image for larger version  Name:	IMG_4698.jpg Views:	0 Size:	104.3 KB ID:	1265012 Click image for larger version  Name:	IMG_4685.jpg Views:	0 Size:	366.5 KB ID:	1265018 Click image for larger version  Name:	IMG_4685.jpg Views:	0 Size:	366.5 KB ID:	1265018 Click image for larger version  Name:	IMG_4685.jpg Views:	0 Size:	366.5 KB ID:	1265018 Click image for larger version  Name:	IMG_4694.jpg Views:	0 Size:	419.5 KB ID:	1265020 Click image for larger version  Name:	IMG_4694.jpg Views:	0 Size:	419.5 KB ID:	1265020
Thank you for looking 👍
Geoff.
Too work geoff , it looks very purposeful all in black , excellent build , cheers tony
Great work Geoff - and a fitting testimonial!
That looks great Geoff. I can see the variation in paint work in some pictures, so well worth the effort. Great history too. Spot on.
Thank you Colin 👍
Geoff.
A result to be proud of. Very nice model of a rarely seen aircraft. I didn't realise that Max Aitkin of Daily Express fame had such an illustrious past.
Thanks Jim, yes I’m pleased with how it’s turned out. I was surprised about Max Aitken too, quite a distinguished career all round 🙂
Great work Geoff, that's turned out very nicely
Cheers Mick 👍
Geoff.
