Looks wonderful John. You must be in modelling heaven combining your two interests like that….
Thanks Tony, the printed sheets are really well done . The flowers that you have to make arePlants look amazing john , the Mother in laws tongue looks real !
Yes indeed Tim, what more could I want :nerd:Looks wonderful John. You must be in modelling heaven combining your two interests like that….
Thanks David :smiling2:Both thumbs buddy.
Hi Mark, the part count of the premade parts is high, they certainly didn't hold back on parts esp containers .I've seen this on amazon and assumed all the bits and bobs were all moulded plastic,just plonk in the greenhouse! How wrong was I! I'm impressed with how complex it really is, nice job so far John looking really good.
Hi Graeme , thanks. Now trying to put the actual green house together. Clear plastic pre formed sheet , with end tabs that won't go through the slots in the opposing wall ! When they do as soon as you move it to attempt the other end, they all fly out !The plants look good John, well worth the effort.
570 I could have done with the help of Matron , but think I have sorted the battle with the flexibility of the premade glazing sheet. Photos tomorrow of the state of play , the base now has its floor in along with the bottom timber sections, so it's more of a solid shape .Drying in between some steel sections to keep it in shape .Nice progress 453. This looks more like something I've seen in Matron's 'Servicing Bag'
570
John, you do have green fingers even if they're made from paper and card. Very nice.Good evening to the gardening section of the forum, Percy here with an up date on to-days horticultural offerings.
Boy is this messy, every thing has to have glue on, paper and wire, more fun when you have to roll a section of green paper and put some flower heads in, once that is done then attempt to get it into a pot. Only to find the roll is not tight enough. Some of the papers have to be cut to 40mm long by 20 and with up to 5 wires in as well .Covered in glue trying to unstick fingers from leaves and the like, still its looking f
Thanks for looking in, comments welcome.
Percy.
Does the Mother in laws tongue grow well in the UK? They thrive here but attract lots of snails that hide in between the leaf base as they like the water trapped there.Plants look amazing john , the Mother in laws tongue looks real !
Ours is doing quite nicely in the window sill in the kitchen, although it's an indoor plant here in the UK and so for us snails is not an issue - at least in my experience.Does the Mother in laws tongue grow well in the UK? They thrive here but attract lots of snails that hide in between the leaf base as they like the water trapped there.
........maybe you can persuade Mrs R to hold it:rolling:
Thanks Richard, the best thing about these they don't die !John, you do have green fingers even if they're made from paper and card. Very nice.
Quite right Andrew, they certainly wouldn't survive outside.Ours is doing quite nicely in the window sill in the kitchen, although it's an indoor plant here in the UK and so for us snails is not an issue - at least in my experience.
I may be wrong but I'm sure it wouldn't survive the winter temperatures.... We've had sub-zero overnight temperatures every night for about week now and we're only 50 miles north of London.
HTH.
| Common Names | Snake plant, viper's bowstring hemp, Saint George's sword |
| Scientific Name | Sansevieria trifasciata |
| Height | Up to 40 inches |
| Light | Bright, indirect sunlight (some direct light is ok) |
| Water | Once a month; keep the soil dry |
| Ideal Temperature | 60° to 80°F (16° to 27°C) Prefers warm to hot temperatures |
| Soil | Free draining soil |
| Fertilizer | Doesn't require it. For fast growth, fertilize once in the spring and once in the summer. |
| Pests | Fungus gnats |
| Toxicity | Toxic to dogs and cats |
That was mentioned, but it was then suggested that the roof came off ! So you will see from the photos that I've started to add supports to the upper sections. The idea now os to get to plexi cut to size and make up a rigid roof.Hi John
I think that often it isn't until something is finished that the structure becomes rigid. In this case you'll need a third hand - maybe you can persuade Mrs R to hold it:rolling:
Certainly not, siad it looked like a dead snakeJim, she won't even hold mine!
I was trying to ignore and wash my mind with soap and water when I saw Jim's comment...so wanted to reply. :tears-of-joy::tears-of-joy:Jim, she won't even hold mine!
Thanks Jim, hopefully the new roof will make it.Hi John
A few difficulties but coming on a treat.
