Help please with products and items
I found a dinky ERF fire tender which needs to be lovingly restored rather than throwing it away.
I need to fill in a number of holes on the roof, where in the past would have been, a hose reel, a search light and piece of metal and over the cab section hooks to secure a wheeled escape.
What can I use to fill in the holes on the roof, some one has suggested tamiya putty , or tamiya epoxy putty quick type 87051 or is there something else I could use?
In the front two holes some led lights as part of the flashing beacon. What do I need to purchase for this effect? Does it come in kit form?
Also how easy is it to do?
Rather than replacing the wheeled escape which I have, I wanted just to replace it with a replica 35ft ladder. In the seventies the fire service I was in would remove wheeled escapes and replace it with a different ladder system.
Any help would be gratefull..
Peter Collins
Are you stripping it down to make things easier?
There's a couple of guys on YouTube that do this shirt of thing to diecast
Hope you share your progress with this project
Hi
The reason for wanting the stripping the model down is for the following reason. In the mid to late sixties my dad would take me on a united bus to Whitby. Going through Lythe village on the outsiskirts of Whitby every time we passed the fire station their was a yellow fire engine.
I thought one day I would try and create the fire engine concerned.
Peter
Ive watched numerous youtube videos on how to most of them show the vehicles being taken into a garage or work area and using a metal grinder to remove the paint. But this would have caused issues as the model concerned slightly raied lockers.
Back to searching the internet for further inspiration to no avail. Some people sweared using dettol (didnt try) would do the job, acetone (nail polish tried some but to no avail.) Some even suggested using white vinegar (10% acidic) also mister cleaner oven spray. One even suggetted jeyes fliud or brake fluid to remove the paint.
I picked up an old nail file on the wifes dresser( guess what it wasnt an old one but a new one in the dog house again lol lol). For fun I just started to use it on the model concerned. Found that the paint on the model wasnt put on evenly from the manufacturer (typical).
After a number of hours of pure delight using the nail file the paint has started to come off. By mistake and in a little pain I picked up a small diamond file I had on the computer table which workd a treat until the paint clogged the file and I was continually having to remove the paint. Due to my arthritis I gave up for a number of days. Only to find out that the wives nail file was a 180/240 grit which was not very rough.
I had some 100 grit boards in my tool box and those did a better job until again the paint clogged the grit file or the file becoming dull.
I then dismantled the model to make it easier to clean remembering to put all the items inluding a screw in a bag in a safe place.
The wife wanted the cupboard underneath the sink cleaning as it was becoming a mess and we needed to throw away anything that was not being used. I found a pack of astonish oven cleaner which dad gone hard. Rather than throwing it out I found an old piece of wire wool and used the these on the model to get reasonable results.
This method is good on parts of the model where the paint has been thinly coated but not other areas.
First image of the model roof.
new images
Monday 04/05/2026
Will post 2 more images
I will try and update when I have cleaned a little more of the model
I personnaly use a wire brush on my drill press for stripping paint and rust of objects like that. A wirebrush is strong enough for stripping paint but not strong enough for removing raised details. If you can, try it out on an old matchbox car or something.
Example of a wire brush for drill:
Goodluck :coffee:
I had 2 mates that did a lot of diecast cars. They'd just dump the cars into a container of standard thinner (aka cellulose or lacquer thinner), after ensuring all plastic parts had been removed.
It stripped the paint off easily.
Life's way too short to remove it mechanically!
How about a two-part epoxy for filling the holes? Something like:
I have restored loads of these diecast vehicles and just used standard paint stripper to get them back to bare metal and then prime and repaint. For filling the holes the epoxy putty will do it or you could put some tape on the inside where the holes are and drip some epoxy into the holes. The tape will stop the epoxy running through. Finish off with a fine surface filler if required.
Check out Steve Flowers Model supplies limited on the web for any spare parts that you need. The specialise in vintage models and make reproduction parts etc. Enjoy the restoration.
I have an old dremel with numorous attachments but the vibration from it hurts my fingers as I have arthritis. the one thing I would have used a drill with some wire brushes If I could control the speed and the vibrations werent so bad.
tried acetone and some cellulose to no effect or I might not have left long enough.
I dont know why but the paint in certain parts is thicker than on other areas.
Might try and get some paint stripper at the weekend if I can get to the local joinery store..
How about a two-part epoxy for filling the holes? Something like: gorilla two epoxy filler
my plan was to get the paint off first and then get the epoxy filler. As a first time rebuilder I wasnt sure what to use. Will give it some thought.
Peter
Update 05/05/2026
Had a spare hour this morning to try and remove some more paint. Smeared the the cab top area with some astonish cooker and grill cleaner it is a Vegan product, non corrosive does not burn the skin (but still put on some gloves the active ingredient seems to be orange oil. Let it stand for about 15 mins and used some emery nail files it did start to reemove the paint a little easier. Did this about three or four times to remove quite a bit of the paint. Should have read the advise her first. Lol Lol.
Some of the areas are problematic
todays effort.
Peter
Morning
Went to my local model shop to get some paint remover, they suggested trying some expo modellers paint remover. They suggested painting it on liberally and putting some cling film on it and leave it for 24 hours and then giving it a good scrub. images attached.
The paint remover didnt smell like some paint removers, The paint remover states that it is water based, No fumes,. They also suggest checking it after an hour and then giving it another covering and ot use wire wool.
After giving it a liberal covering of the cleaner noticed that it cleaned my brushes, in the process which I last used using acrylic black paint. Lol.
Unable to use the cling film as suggested I put some paper towel in to try and keep the cleaner moist, and also placed it into a sealed bag.
Peter Collins
Update today Sunday...
I couldnt resist it after leaving the model too soak for an 90 mins this is the result so far. I had to use a new hard bristle tooth brush to remove the loose paint. It is now under going the second clean.
Peter
Wow, I'm sure I've stll got one of these wrapped up in the loft.
So what you going to do with your fire engine!?
In the late sixties my dad would take me on a United mystery tour bus trip on a Sunday. We always seemed to end up in Whitby passing through Lythe on the outskirts of Whitby we would pass a yellow fire engine not the normal red colour.
So im going to try ang get the model looking like the one I saw in Lythe.
Thats when I get the it completly stripped and sorted out the number of holes on the roof which need filling . I will be leaving two holes open near the from of the cab and trying to find some one to tell me how to fit LED lights into it.
Also to try get a set of ladders built from wood.
The fire engine at Lythe had initially a wheeled escape ladder on it, then a a 35 metre ladder installed and at on stage a normal extending ladder.
Since the model's latching sytem was badly damaged I removed it and some the other parts such as 2 hose reels and a light had been crushed.
Work still progressing ...
Peter
Update
Since starting to strip the paint from the model I have used the 50ml of expo modellers paint remover. There are a number of stubborn areas which are creating issues still.
I have used old emery nail files in stubborn areas as it seemed their was heavy layers on the model.
Once one side was liberaly coated in paint remover and left for a number of hours I would use either an old hard bristle tooth brush, or a scouring pad which a smooth wire wool side, and even using ear pokes to remove the paint especially round lockers. but these areas are prooving to be stubborn.
I have found using the expo modellers paint to remove acrylic paint easily, but on this model its taken quite a few attempts to remove the paint i dont know what type of paint was used in the sixties. But if have a lot of patience it does work. The cost of the paint was £4.99 for the size of bottle I purchased from Ebay.005.webp
The design of the 50ml bottle is awkward at getting the paint stripper out once you have used 50% of the bottle. Unless you want to squeeze it into a wider container but that may create waste.
Ive attached the latest pictures of the on going cleaning process.
Peter
