Mosquito wasn’t as flexible in bomb load mix though Pete.Smaller bomb load that a Mosquito I believe.
This is a myth that needs to die.Smaller bomb load that a Mosquito I believe.
True, it’s their logo, but none of this will be seen hence not bothering to remove it.Coming along nicely Barry. I assume the nose and tail walls are not visible once assembled? Bad move from the kit manufacturers to add part numbers to The surface detail otherwise. Totally unnecessary on a modern kit really.
Those scribers look really goodThe nose and tail are attached. A good fit with only a little bit of filling and sanding needed.
I have used my new MRP scribers for the first time and they are great, very sharp and I recommend them. I thought I would try them out given how their paints are of the very best quality, unbeatable and these tools are up to the high standards MRP have se
