Thank you Sir.Excellent build Ian. That’s come out very well and is a fitting tribute to a tragic occurrence.
Thank you, most appreciated.Beautiful build and beautiful aircraft. Remember walking around and watching the one that was based at Hatfield BAe Establishment when I worked there many moons ago.
Mike
Is that the one that Kermit Weeks owns now?Beautiful build and beautiful aircraft. Remember walking around and watching the one that was based at Hatfield BAe Establishment when I worked there many moons ago.
Mike
Thanks Mick.A thing of beauty Ian, you’ve done a great job
Here you go. Medium sea grey for the underside, dark green and camouflage grey for the top. (probably should be Dark sea grey).
Maybe not 100% the correct grey for the top but close enough.
Thanks Ian. I thought most were done in a 3 tone finish. My AV set didn't come with FS 639, so I'll have tofakeconjure up something for the underside color...
Allen
BS 639 is light slate grey. Not the colour you might be after. Ocean gray as far as I recall was not included in the BS scheme of things I can say that if you are into Vallejo Air the paint you want is 71,273 for Ocean grey, thats for the top surfaces grey. the bottom is 71.307 MSGNo biggie, as I can whip up a good substitute for the BS 639 in my secret underground lab!!!..........
I cannot answer honestly as it has been so long (1980's) but you could be correct.Is that the one that Kermit Weeks owns now?
