I spent several hours last night adding the small bits to the chassis - it is a puzzle, to sort out where the bits go - luckily the part numbers are correct, otherwise it'd be like a MENSA test!
It does help to have an engineering background..........working out how the fan drive worked took
quite a time!
The instructions (!!) would have you butt join the steering column/wheel/support to the chassis floor ( no hole, or anything ), so I added two small pieces of tubing to the bottom of the shaft to give it some support.
I masked up the edges of the hull, where the mudguards will join ( not fitted yet, as I want to paint the top track runs ), and sprayed the track units & the interior with grey primer. I'll break out the small brushes, for the interior detailing, which may take several attempts/touch ups. I may start dry fitting the upper bits, to actually work out what you actually will be able to see through the open hatches., and concentrate the detail painting in those areas. ( I've just noticed, I haven't added the battery, yet )
It must have been extremely uncomfortable travelling in this thing - the engine burning your elbow, and I bet the noise was a little overwhelming!
