wotan
- Joined
- May 16, 2018
- Messages
- 1,311
- Location
- Brome Lake Quebec
- First Name
- John
These are knife-based cutting machines, right? I looked into those (of a number of different brands) a few years ago, partly with an eye to using one to make spray masks and partly for cutting plastic parts for scratchbuilding. I came to the conclusion that they’re unsuitable for many modelling tasks because of the way the machine works: it has a swivelling blade that it pulls along the material. This means that to make a cut, it always positions the blade slightly before where it needs to start, and ends slightly beyond where the cut is to end. Not a problem if you’re cutting out something like a full-size stencil, but if it starts and ends a millimetre before and after the line on things with a line thickness of a millimetre too, it likely ends up cutting all though bits you actually want to keep.a Cricut and started cutting your own masks
