Letov s16 in 1/72 KP models
yak face
Staff member
Tony
Sheffield
After seeing steves ( @Steve-the-Duck ) amazing scratchbuilt Avro Aldershot , it reminded me of this aircraft . A fairly obscure subject but one that I always liked the look of , so I bit the bullet and got one . Its the ancient KP models kit , quite reasonable for a 1982 tooling . Its got a bit of flash and mould seams to clean up but nothing major . I started with the cockpit , the neatly done instrument panels (which were wooden on the aircraft ) came up nice with a careful paint and the rest of the pit is ok too. I just have to put on some suitable belts then I can get the fuselage together .IMG_8130.webpIMG_8131.webpIMG_8132.webpIMG_8133.webpIMG_8134.webpIMG_8136.webpIMG_8137.webp
A nice looking kit Tony. Looks to have some nice surface detail. Great start on the cockpit.
Cheers joe its an interesting aircraft . Large for a single engine ( bigger wingspan than a swordfish at 50 ft)
A plane I've never heard of. Love the box art - old fashioned but certainly eye-catching.
You're off to a good start.
Nice obscure choice Tony. Following along...
Nick
A good crack at this today has seen the assembly really motor on . I glued the fuselage and wings yesterday so today I was able to sort the seams and start getting some of the struts and stuff on . The eight exhaust stubs were just moulded on pips so they were drilled out and some brass tubing fitted. As I’m doing the in service bomber version ( as opposed to the flying school trainer option ) there are twelve little bomb pylons to fit under the wings , and while I was under there I fitted the undercarriage struts too. Its now had a blast of Hycote primer , as well as the top wing , radiator and propeller . Next up is a quick scan to see if the primer has highlighted any areas that need remedial work then its about ready for paint .IMG_8149.webpIMG_8150.webpIMG_8159.webpIMG_8160.webpIMG_8161.webp
A first for me to inspire someone else to a build! My ego is suitably boosted!
This beast has very long, narrow wings...
A very good start on the interior, nice wood effect. Me, I use 1 mm Tamiya tape for seatbelts in almost all my builds, saving the Italian stuff. Just needs a tiny dash of dark brown for shading with a spot of brass colour for the the buckles.
Older KP kits get a lot, IMHO, of unfair criticism. What kit of that age doesn't need a bit of clean-up? And if the parts fit, all the better. I mean, I've built 'modern' AModel kits, which are a bloody nightmare!
Ive done quite a few Amodel beasts too steve , this is like Tamiya compared to some of them ! One of the worst and a kit that almost beat me was the Yak 28p intercepter . I had to put it back in the box halfway through and come back to it when I had regained some resolve and finish it off ! Another was the Kamov ka15 helicopter , the rotor head assembly was just about all replaced with bits of rod and strut as the kit parts were absolute pants .
AModel. Would it kill them to have locating pins and mounting holes. Ooh, look, lots of mounting points on this KP! Yay
Coming together very nicely
Undersides now painted . I used Vallejo metal color dull aluminium but it came out far from dull with a very shiny finish- which would have looked great if I was doing a polished natural metal aircraft but this is silver painted doped linen bird . After this dried ( not more than ten minutes in this weather !) I gave it another coat but this time with white aluminium which doesnt look quite as bright . Once this is masked up ive got to figure out what to use for the khaki top , online reference is very scarce and no colour pictures or original aircraft survive . I suppose that means it cant be wrong whatever I decide ! IMG_8165.webp
Undersides now painted . I used Vallejo metal color dull aluminium but it came out far from dull with a very shiny finish- which would have looked great if I was doing a polished natural metal aircraft but this is silver painted doped linen bird . After this dried ( not more than ten minutes in this weather !) I gave it another coat but this time with white aluminium which doesnt look quite as bright . Once this is masked up ive got to figure out what to use for the khaki top , online reference is very scarce and no colour pictures or original aircraft survive . I suppose that means it cant be wrong whatever I decide ! View attachment 1291226
Invariably, I just use rattle-can Humbrol silver for my RAF silver wings, and the pair of CR.20s were Humbrol aluminium, which does look quite dull
You've made good progress.it does indeed have long, narrow wings. Metallic paints often come out differently to what you expect. Looking very nice under paint.
A coat of klear sealed the paint and gave a nice smooth surface for the decals . I thought the decals might be a bit tricky as they are obviously quite old but they behaved perfectly - good colour density and quick to release from the paper . All 10 are now on ( yes, a relief from tiny stencils ) next up is a sealing coat then time to get the top wing on and think about what im going to rig it with ( it had quite thick rods for bracing ,a bit like the swordfish ) IMG_8190.webpIMG_8191.webpIMG_8193.webpIMG_8194.webp
The rigging rods dilemma has hopefully been resolved . At first I was going to use acupuncture needles , its something ive used before and gives a good representation of a rigid rod but I didnt have enough . Then I remembered I’d got some fibre optic strands in the spares box . I got these a few years ago , theyre from a cheap fibre optic UFO type lamp that was on sale after xmas . I think it cost me a pound or something but I remember thinking ‘those might come in handy sometime’
Anyways , I cut a load off it and sorted through to get the 8 straightest then cut them to size and painted them. Next I’ll see if I can fit them before i add the top wing or if Ive got to do it after . IMG_8195.webpIMG_8196.webpIMG_8204.webpIMG_8206.webp
Definitely an obscure kit for me but the name surely "letoff" a loud chuckle.🤣 You're doing wonders with this kit, Tony. Good thing you solved old kit issues with out a "letoff" of expletives. I just had some curry so expect some "letoffs"...what a name.
Seriously I like these weird subjects...I mean obscure planes and tanks.
Wabble
Great progress and a very clever, thinking outside the box, solution to the bracing struts issue.
