Modelcraft 1/48 F82B ‘Twin Mustang’
Just caught up Dave. Some very nice work going into this one. Keep up the great work.
I’ve now got both wings on.The dihedral looked far too much.so I cut them partly off and added plastic card packers at the upper wing root.So of course more filling and sanding was needed.Then I rescribed the aileron and flap panel lines.
I’m now fitting the canopies. I’ve cut the left hand one so I can have it in the open position.Sliding part will be fitted after the kit has been painted.
Looking good dave , cheers tony
After countless sessions of filling and sanding I’ve finally got a coat of paint on it.Vallejo metallics range ‘white aluminium’ over Alclad black primer.It needs rubbing down in s couple of places and another coat putting on.
I had a problem with the silver paint. Probably because it was acrylic and it was very cold in my garage.So I cleaned it all off with IPA. Now it’s been resprayed with Alclad gloss black. And I’ve painted the anti glare areas with Tamiya tyre black. Will mask them off and start on the silver.
Nice finish on that gloss black. I bet Alclad allu would come out nice over that.
What was the problem with the silver paint Dave?
The paint bloomed on two areas.probably because I was using acrylic paint in near freezing temperatures.Should have stuck to my usual Humbrol enamels
I’ve resprayed the model with Revell enamel aluminium.Finally a finish I’m happy with. The canopies are done as well.
