Today, I finally got myself to try spraying the Type 3 Chi-Nu again, with the same paint that was giving me trouble earlier but now using the manufacturer’s thinner. This is what happened after I had thinned the paint and started spraying:
Still the same threads as I had with cheap cellulose thinners
Remembering Tim’s advice to use more pressure, I cranked that up to about 2 bars, which is roughly twice what I normally spray at, but the problem persisted. I then thinned the paint some more, adding much more thinner than I would normally use, and kept the air pressure that high. This got the paint on fairly smoothly and with no, or next to no, threads forming.
When I was done, I happened to glance at the filter in my spray booth, and was startled to see:—
The
whole damned thing was covered in a membrane of paint! I took it to the dustbin where I got the paint off easily by means of a large, stiff brush, so I didn’t need to replace the thing, but I shouldn’t need to be doing this after spraying one medium-sized tank.
I guess part of the problem is me not being used to this type of paint, and so underestimating the amount of thinner required. But even considering that, I don’t think it’s worth the bother and I don’t quite see how other people get along with it. I doubt I will be using, let alone buying, any more Mr. Color lacquer paints — but I like their aqueous paints a lot, so I will be using those
