Nick's Aoshima 1/12 Kawasaki GPz900R ......... TOP GUN
I'm pleased to report that with just three weeks remaining, meaningful construction has begun!
The tweezers are holding the sprocket to the rear wheel while the glue sets. Getting the engine and airbox into the frame was quite tricky...
Nick
Managed to make some more progress on the assembly. Got the footrest hangers in place and left overnight. The actual footrests themselves will be left until pretty much the end for fear of knocking them off. The brake and gear change lever had to be fitted behind the hangers and are a worry.
Then the exhausts - these lined up quite nicely straight off which was pleasing as the silencers and collector were all glued up by eye before painting. The downpipes each had three ejector pin marks to deal with along with their longditudinal seams prior to painting. They have spent a week or two on numbered croc clips so that I knew what order they went in.
Next it was onto the bracketry and plumbing for the radiator and oil cooler, so after another overnight wait, today I have added these parts.
So disappointing when you only notice an ejector pin mark after its too late..... :rolling:
Lastly, I got the front-end fitted. This had already been built up and the brakes and anti-dive units plumbed in.
Pretty much all the other parts can now be fitted, but the whole thing is pretty fragile. I have been working on the tank and panels, but we'll save those for the big reveal. Back to work for a few days now, but its looking like I might even finish on time. Fingers crossed.
Thanks as always for looking in.
Nick
That is really looking the part now Nick. Detail looks good.
Thanks Guys. Still some tricky small parts to fit.
Nick
Looking really good. The chain in particular looks real.
After getting a little bit done most evenings this week, I am nearly at the finish line although not without a few issues. The inner rear mudguard went in ok, but the outer complete with tail light took a bit of care and persuasion. One of the rear frame rails was slightly off and it needed the help of a couple of pairs of reverse action tweezers keep it all in the right place whilst the glue cured.
The rear bodywork went on reasonably ok but the front fairing has been a right pain and I'm still not happy with it. Nevertheless, the next pics will be in the completed section for better or worse when I can get some decent photos. Thanks again to Jakko for organising the group build and to everyone that's had a look in here and followed along.
Nick
