Thanks Vaughan appreciate the support! I'm on to tackling the engines ,first the gear up booms. I ordered some a/m
resin nacelles and thought they came with the end adjustable cooling cowls as pictured in the ad(not!) be forwarned ordering stuff ask questions!
they also need lots of sanding and trimming,even had to remove a blob of resin that dribbled down each side,hey at least it was the same on both parts!
Next I had to do some surgery as the kit supplies an open and closed cooling cowl on each boom,WHY!?
Card stock added over the lower cowl area,later I'll add some mesh back in
Closed cowl from the gear down boom needs a plug to get the correct length back and a strong glueing point
The cowl ring side needs the same
Trimmed and sanded
Glued in place with the better looking side turned out.the blems will be sanded out later. I left the nasty ones inboard so they wo'nt stick out as bad.
I'm starting to get a grip on ship 1,now I need to research the engine mounting detail and figure out how much ship 2 cowls will be opened up, if at all! I really want to have an engine in mid removal for the finished build but wondering how authentic i can make it look. Any pics of an engine removal would be great not having much luck finding any on line.
