P-61Black Widow 1/48 Revell
This is one great thread trey, the amount of work youve put in is really going to show in the finished models , are they both going to be black or is maybe one going to be green/grey? Keep up the excellent work mate , cheers tony
Looking Very good now. I can hardly wait to see the paint go down.
Great progress, well done that man.
Thanks Tony ,yes a green /grey A and a all black B. Ian ,Colin thanks and Yes finally some paint I had a long airbrush session and got quite a bit painted today.
Started with a green zinc coat over the canopies
I applied some OD green on ship 2 as a gude coat and it still needs some sanding around the seams and canopy join areas.
Finally some black goes down on ship 1. First glance looks pretty clean and no seams or blems showing!
This calls for a tall frosty pint me thinks!
Wheels are ready
Booms for ship 2 need some weight before attaching to the Pod
Great progress trey, the paint job looks excellent. Glad youre doing one in the OD /Neutral Grey scheme its good to see one in a different scheme. Wheels are looking sharp too! , cheers tony
Tony thanks! I let the black paint sit in the sun for a few days and the filled areas did shrink a bit as I knew they would. I wet sanded those areas down and got rid of a few dust blems .
I then based it with some testors silver so I can salt chip the leading edges and canopy frames a bit. I'm hoping to be able to spot sand a few rivet and panel details as well showing some maintenance wear. Some blems around the canopy showed up after the silver base geuss I'm not done sanding.
Ship 2 booms on aligned and seams filled
Looking very nice now.
Good to see one in green/grey as well.
Awesome work going on there Trey, it's really coming together. By the way what's that float plane in the background? Also you've got one nice workshop great artwork on the ceiling.
Vaughan
Ian thanks,I could'nt just do 2 black ones! Vaughan appreciate the kind words,the float plane is Connors project he'll be posting his very first thread about it soon! The shop is compliments of Hurricane Charlie,it was reborn from the rubble that was left of my original Man cave. I hope to get some black on ship 1 again today. Right now I'm going nuts with Aires resin engines that arrived in the mail yesterday they are kits unto themselves!
After fixing some missed blems I started using the salt method for ship one
Then some Testors gloss black reduced 30%
After rinsing and scrubbing with an old tooth brush
Ship 2 progress engines and nacelles in place
Some great work since i last looked in Trey, both coming on a treat and looking very good
Excellent work as usual Trey.I will have to try the salt myself.I wasnt happy with the results i got withmasking fluid.
that salt method works really nicely,i might try it myself sometime
mobear
Thanks for all the comments from everyone, I appreciate the support. I'm struggling to stay focused here as the builds are branching off in many directions. I'm hoping to start working on the base soon and the support equipment. In the meantime trying something new for the 'spinning prop' effect. I started with some sheet plastic and using a circle cutter and some masking added some rings
added some sprue to the spinners in place of the props and tapered the ends
masked the reverse side for the 'prop'
after the color on one side the mask was pulled back to allow for a blend area for the black
masked removed
then some rubbing compound on the color side,this leaves only a trace amount of color toning down the effect.
Finished results
What do you all think ? Is it passable or should I bin it and stick in the static props?
Well i think they look great Trey the only thing i would do differently is to make the rings on the inside a lot fainter/ not as deep if you can understand what i mean so they don't show as much
