Placing compressor on the floor?
BattleshipBob
Afternoon chaps
In the modelling room I am finally going to leave the compressor set up as security will be very good.
It's going to be on the concrete garage floor, now should I put it on top of something else?? Only concern I can see is draining the moisture trap, knees are not what they use to be lol.
Good question.... Mine is on the floor in the kitchen...but I don't have a choice..... Would be interested to here what the experts say!
Thanks for asking.
I would put it on a rubber mat,may help with vibration through the floor if any ,other than that only your knees know the answer!
A doormat would do fine - just make sure that the vulnerable bits ( regulator/moisture trap/air hose ) aren't hanging out, just waiting to be kicked!
I’ve only ever had mine set up on the floor. I do place it on an upside down square of carpet (off cut) so it doesn’t damage the flooring, though that won’t be an issue for you. A carpet square would cut the noise transmission down a bit as will. I set the compressor to a high pressure and feed a secondary pressure reducing valve mounted on the airbrush holder so I can easily change operating pressures.
My set up is the same as Tim's except that instead of carpet my compressor is on a rubber mat.
I always release the pressure at the end of a session by removing the drain plug at the bottom of the tank. I then leave it out until the next time I airbrush. My thinking is it allows any moisture in the tank to drain/evaporate.
Mine is on the floor in the apartment, mounted via rubber washers to a wooden base, which has rubber feet to try and reduce vibration noise, neighbours underneath have never mentioned noise.
Same here..... And there's always moisture to some extent or other.
A couple of layers of an off cut of rubber underlay for carpets should keep it quiet. As for the knee's up on a shelf us the best way round that one. The compressor not your knees.
I have a couple of bits of wood under the feet of the compressor so I can reach the drain valve more easily.
Thanks Gents, a goldmine of info there!!
I will have some spare insulation left over from the room!!
