Revell 1/32 Spitfire Mk2a
Vaughan
At last I've completed a kit!! Its been a while what with continuing heart problems which I'm glad to say are all sorted now. No more interventions and following the MRI scan, back at the beginning of February, my heart is good to go.
I've been beavering away at this one for quite a while, no build thread, this ones been built many times, so just a few cockpit details. This one's straight out of the box with some home made Sutton harnesses. Build went without any real problems. Closing the fuselage was bit of a struggle the cockpit tub was a tight fit and needed some sanding. All in all a nice well detailed kit. I see they have just brought out a Mk.IX so I may have a go at that one. Anyway this is not one of my best builds but it's a start back into the modelling, all comments welcome.
View attachment 280512 View attachment 280513 View attachment 280514 View attachment 280515 View attachment 280517 View attachment 280518 View attachment 280519 View attachment 280520 View attachment 280521 View attachment 280522 View attachment 280523 View attachment 280524 View attachment 280525 View attachment 280526 View attachment 280527 View attachment 280528 View attachment 280529 View attachment 280530 View attachment 280531
Good to see you back on the forum, I was just wondering that I hadn't seen any of your work for a while. Nice build.
Simply beautiful vaughan, stunning cockpit, cheers tony
Great to hear you are feeling better and your heart is okay now Vaughan. And what a return to the forum, this is a great looking build, very inspirational. I like the subtle weathering.
Thanks guys it good to be back. Just pulled out a Trumpeter 109 trop so will be next on the bench.
I'm going to echo the thoughts of the rest of the lads, excellent work Vaughan, really like the cockpit;)
Perfect. I've always preferred the temperate scheme, probably because it could have been my first build as a kid.
Hi Vaughan
I'm so glad you're well and the heart problem has been resolved. It sounded so very serious and it's great to have you back.
The Spitfire is stunning and believe me I know this particular plastic intimately (having completed no less than 7 kits of this myself!).
The cockpit detail, harness etc all look just right. The paint scheme itself is flawless (as usual) and it all makes up for a great looking Spit. Nice to see an actual mk.2 for a change instead of another mk.1 backdated kit.
Kit-wise I think the Revell my.2 is a great kit for the money and filled a really noticeable hole in the 1/32 market. I think as an (almost) OOB build you've completely smashed it. It's a lovely looking model.
Question: did you find that fitting the canopy was a struggle? Every build I've done of this kit has required quite a bit of pressure applied to the canopy to get it to sit on the rails. I don't think it's anything to do with how I built them I genuinely think the fuselage is too wide for it.
Anyway...
Great work (as always) and great to have you back
All the best
P
Thanks again Guys.
Paul no real problem with the canopy. The rear section is a little narrow but if you push it down it then doesn't line up withe spine as it is then too low. So I left it and it's not really noticeable. What happened to the 7 you built? did you ever post them on the forum?
Here's one of them. You may have to scroll through the thread as some of the pics seem to be missing but you should get to some pics without the photoshopped backgrounds.
http://www.scale-models.co.uk/threads/battle-of-britain-part-3-spitfire-mk1.22753/
I built 3 wheels up and 4 parked. I sold the 2 with wheels retracting to a collector together with 2 parked on airfield grass bases.
I still have the motorised wheels up version together with 2 more on display bases. The ones I have are: Geoffrey Wellum's aircraft (92 sqd) and another 610 squadron.
It was quite a while ago now I built 5 together (which I featured on the forum) and then another 2 later on (after I'd sold my display models).
Hope you like it. I couldn't find my original build thread, it was before any aftermarket stuff became available so I was spending time modelling fabric ailerons etc.
I find the rear glass is too narrow to match the lines of the fuselage (although I have fixed that in later builds with some sanding and pressure on the fuselage sides). I still believe the fuselage is slightly too wide though for both the rear glass and the canopy.
Anyhoo, you've done a great job with yours and it's great to have you back
P :)
Hi Vaughan
One very nice Spitty you have there, excellent camo work...
Thanks for that Paul I didn't realise that it was that long ago.....they look great. I presume you have used PhotoShop(very skilfully I might add) to create the images which of course needed some very well built Spitfires!!!
"Not one of my best" he says! I'd give my left arm up to the elbow to be able to produce results like that!
It's good to see you in better health and back at the bench Vaughan.
Yes, it's photoshop - a good tool but not as important as the model building.
I won't be posting builds for a while as I'm in the midst of moving house and all the upheaval that entails. Could be as long as a year, by which time I'll be chomping at the bit to get stuck into a build!
I do have the forum though to see me through the move, and I can continue to enjoy the models from the likes of your good self! Keep 'em coming!!! and if you do build the mk.IX I'd be very interested to see the progress. ;)
All the best
P
Excellent build, Vaughan!!
I'm glad to see you working on new projects. Looking forward to your next 1/32-strike!
I hope you are always better and that you will be fit again soon!!!!!!
Stefan:)
