Review - Dspiae (ES-A) reciprocating sander
pjgtech
Peter in Kent UK
Swale Kent UK
Peter
Dspiae reciprocating sander review:
Had my first proper use of this sander today, so here's my thoughts....
Its not cheap, at £37 ish, got this one from our very own SMS, cheers.
But its a gadget, and you can never have too many gadgets/tools, right?
It comes in a lovely hard plastic case with flip up lid.
Click image for larger version  Name:	Dspiae sander10dec24 (1).jpg Views:	0 Size:	385.2 KB ID:	1243060
The sander has interchangeable heads (x8), some are small, some are larger, some are pointed, some are rounded, so you get a good selection.
I can see that it will be very useful for many small parts.
Click image for larger version  Name:	Dspiae sander10dec24 (5).jpg Views:	0 Size:	296.0 KB ID:	1243061
It also comes with two sets of sanding papers, which I thought was very good. Each set has one sheet of each grit (180,280,400, 600, 800, 1000) and each sheet has about a 12-16 of the smaller sanding pads, for each shape sanding head, all pre cut and with adhesive backing. So you literally have a fair few hundred pads to start with!
Click image for larger version  Name:	Dspiae sander10dec24 (2).jpg Views:	0 Size:	364.2 KB ID:	1243062
The heads simply snap on/off the sander, much like an electric toothbrush, and indeed I would think the insides of this sander are also very much like the mechanism of an electric toothbrush.
Click image for larger version  Name:	Dspiae sander10dec24 (7).jpg Views:	0 Size:	491.5 KB ID:	1243063
It is powered by a built in Li-Ion battery, charged via any usb connection, eg: mains, laptop, power-bank, etc. I have a laptop near my model space, so I will use that to charge the sander, although it came pre charged and has not yet run out of power yet.
When its charging the sander has a large green light that illuminates, not sure if this will be red when its low or needs charging?
Also note that the sander does not operate whilst its being charged, so you have to disconnect the usb lead for it to work.
Click image for larger version  Name:	Dspiae sander10dec24.jpg Views:	0 Size:	588.5 KB ID:	1243064
It has three speeds, selected by the power button on the sander. It also appears to have a sensor on it, so if you press too hard, it slows down and then stops, until you release the pressure, again a bit like most modern electric toothbrushes.
The build quality seems to be good, it feels solid in the hand, a nice weight, not too heavy but not too light, its also a nice size, not too large/bulky.
So how does it sand? well its reciprocating, so the head is moved in and out very fast, the total movement is about 2-3mm I think.
I got a couple of bits from my next build (1:76 Airfix DUKw amphibious vehicle) snipped a couple of parts off the sprue and hence found a couple of bits that needed sanding down.
This chassis has a small dimple that needs smoothing down. Here's before (sorry, rubbish photo!)
Click image for larger version  Name:	Dspiae sander10dec24 (8).jpg Views:	0 Size:	310.1 KB ID:	1243067
And here's after using the sander, NB, it still looks a bit rough in the photo, but to the touch its really quite smooth.
Click image for larger version  Name:	Dspiae sander10dec24 (9).jpg Views:	0 Size:	263.9 KB ID:	1243068
And here's another example, the top canopy and another dimple that needs sanding....Before...
And again, here's after using the sander, and adgin it looks rough in the photo, but is actually smooth to the touch.
NB: in both the above this was initially using 280 grit, then 800 grit then finishing with 1000 grit, and both took about a minute each time, switching the heads literally takes about 3 seconds!
These were the heads after a few minutes playing around sanding both the bits above, plus a few bits of sprue, etc, so they are clearly worn, but still have more use left in them, so they look like they will last a while before needing changing.
Click image for larger version  Name:	Dspiae sander10dec24 (13).jpg Views:	0 Size:	429.1 KB ID:	1243069
So what do I think?
Well, prior to getting this sander, I was using old fashioned small files, those little foam sanding strips, and plain sand paper. They all have their place and uses and I'm sure I will continue to use them.
But, I can also see where I would use this sander. It will be useful for when you need to do lots of sanding, eg: cleaning up parts on/off the sprue, after snipping, after filling seams, etc, etc.
The sheer variety of heads also means you can really get into those little places that can sometimes be hard with other implements, and the variable speed option is also useful.
Overall I think its a bit expensive for what it is, I would have been happier at say, £20, maybe £25, but I think £37 is top end! But I do thinks its a useful bit of kit that will get a fair bit of use. I would rate it, hmmm, say 7.5 to 8 out of 10. (If it was cheaper I think I would have given it a 8.5 to 9).
NB: You can buy replacements heads (£5 for set of x8) and replacement sanding sheets (£3.50 per sheet with about a 100 small shaped pads on each sheet).
That looks better overall value than my Proxxon sander, which I think was around £25, but then I had to buy the power pack for it, the lisy price of which is £40-ish, but I found a new unused one on ebay for £20. The sandpaper is more expensive too.
Good review Peter. I have one coming this week, so am now glad I bought it :D
As above Peter. Great to get an honest appraisal of a product before purchase.
Update: Have used this little sander a few times now and it works well.
Did some more sanding today and the interchangeable heads are very useful indeed.
Went from a flat surface to a large curved surface to a tighter curved surface all very easily, just swapping the heads over.
I've also used the sander a few times, and its still on its original charge, not had to charge it up once yet.
So still very pleased with this little sander, a very handy bit of kit.
Used mine a few times now as well. It’s most useful for sanding filler in ejection pin marks flush. Not so useful for things like mould lines, I find the scalpel used as a scraper is much quicker. Personally I wish its head moved a little quicker, but it is certainly useful. The sledge head (flat with a curved end) is probably my most used shape.
Useful review, I might see if I can sneak one past missus Miko's financial scrutiny!
First time I saw one of these was on the YouTube channel of a 'garage kit' figure builder, mostly exotic ladies in their skimpies but the guy (South Korean it think?) was very adept at bringing out their detail with such a sander!
Miko
Been using a lot and find it handy. Bought spare heads so I have the usual grits set up, so easy to switch heads from coarse to fine
Got one for Christmas works a treat, also got a circle cutter thats great to use and cuts really well, recommend both
Simon
Simon
I got one for Christmas too, came in handy for the 140 or so wheel parts that needed sanding on my latest build.
Had one of these for about a year now and whilst I find I rarely use it as a power tool, I do use the interchangeable heads on their own by hand for precision sanding. :)
what Dspiae should do is bring out a snap in handle for the heads to turn them into a hand tool. 🤷‍♂️
