Rick's Airfix 1/24 Hawker Hurricane MK1
I've taken to using plastic wrap (the food cling film stuff) on larger surfaces and the edges in Tamiya tape. I started doing that when I realised I needed to order some more tape. You just have to ensure you don't pierce or rip the wrap plastic.
Canopy masked. I had some issues with this. At first I sprayed all the glazing with Humbrol Clear which resulted in fogging and speckles. After washing it all off and polishing out the worst bits I coated it in Johnson's Klear and got a superb result. Humbrol Clear is most definately relegated to sealing cockpit decal from now on.
As Barry says, the underside pre-shading looks good. I do pre-shade and sometimes it doesn't work, but post shading is always there to save the day !
\ said:
Underside masked, I just need to edge seal here and there with Maskol for a bit of added protection. Building 1/24 scale planes consumes a lot of masking tape!
Rick
Have you considered not masking under the wings at all?
I mask under the fuselage and any areas sticking out (such as the rad) that will catch overspray when I shoot the sides of the model, but with the wings I just shoot down and get a good delination between upper wing and lower wing colour that way.
\ said:
Rick
In hindsight Barry that would probably be a good way to go. This is my first time building any aircraft bigger than 1/72, I'm learning that techniques that work in smaller scales don't always transfer to larger scales.
Nice job, shame about the Humbrol clear, maybe it's not as good sprayed
You are doing an excellent and a very solid built.
Magnificent so far!
Greaseproof paper works well too & is more robust than clingfilm
Rick. I would suggest just adding a drop of white to the green, thin it heavily, then just spray the centres of panels. Don't worry if the contrast is then too great just knock it back by spraying a very heavily thinned green in mist coats drying down in between gradually reducing the contrast until you get the look you want. It's very controllable that way and you get a good modulated effect.
Not happy with the finish of the camouflage I re-sprayed both colours, again by freehand and although better it's not as I sharp as I would like but it's staying this way now. When the masking was removed some areas of paint bleed showed around the wheel wells but these were easily dealt with along with a patch of paint that came off with the tape.
I have been using gloss varnish from Vallejo and Humbrol Clear with acrylics and enamels over the last few years with fairly disappointing results so this has been coated in Railmatch acrylic varnish and has dried much better, the drawback is that it needs thinned.
When dry I can move on the masking and painting the gun muzzles and exhausts before applying the decals, thankfully there are relatively few to apply.
Landing gear fitted, what a dreadful fit though. One of the side stays has shed a short section on rod and I have discovered another missing part - the upper leg fairing for modelling the gear down is missing so I will have to butcher the part supplied for the gear up option. Masking applied for the exhaust and gun muzzle ports painting task later this week along with some touch up on the gear.
\ said:
First coat of Dark Earth.....it's a bit dark!
Better pic's.
I made the same mistake again with the yellow propeller tips and painted them black first, of course the yellow doesn't like sitting on the black very well so I sanded the tips back to bare plastic and re applied the yellow. When dry I'll mask and finish in the black.
I used to do that.Now I spray my props with white primer.Then I do the tips yellow,mask them and spray the blades black.The Hurricanes looking good.
I've painted the gun ports and exhausts since my last update and also applied the decals with the exception of some that go on the underside because the instructions aren't clear which way round they go. The microset is still wet but when dry I'll need to trim the fin flash and touch in some of the red.
My only setback is some white marks that appeared on one of the under wing roundels, not sure how to cure that.
Looking superb Rick. Hard to see in the photos but the white blotches might just be glue residue. Have you tried to wipe over it very gently with a damp soft cloth? Otherwise from limited experience it may disappear under the final matt varnish. Alternatively you do happen to have a lot of roundel blue lying around at present ;)
