Thanks Graeme glad your looking in.Nice work on the cab Paul, will follow this build.
Thanks Andrew, it was fiddly but fun still some work to do on it.Wow! 'nuff said on that scratchery.....
Thanks Steve the photos really helped.Awesome! That is sooooo much better. Lovely work my friend
Paul, while soaking in all your detail, have to say that the copper linkage pins keep drawing my eye... Bravo !I had to rework the front suspension as it was a solid lump lacking in detail. The axle straps that prevent over movement of the axle were just cast as solid blocks. The leaf spring was removed and made from strips of evergreen. The link arms were fabricated from copper rod with copper pins to allow the suspension a little movement. There is still some detail to add this will be done when this has dried properly. You can see the straps that replaced the solid plastic moulding.
cheers
Scottie
Hi Richard, cheers mate. As far as I can make out Revell and Italeari shared the moulds but not ESCIGreat modifications and scratchwork Paul. I have the ESCI kit...don't know if it's similar to both the Italeri and Revell kit.
Thanks Paul,A lot of vehicles with solid axles had these straps especially X country and 4 x 4 to protect the suspension.Beautiful job. Early Corvettes (before IRS) had the same strap arrangement on the rear axle.
Jim, not a problem mate that is what these posts are for, sharing information and asking questions.Hi Scottie
Front axle/suspension looks so much better. Definitely worth the time and effort.
Thanks Allen for the half track info. Most interesting. Sorry Scottie for clogging up your thread with my question.
Ron, thank you mate they were fun to makePaul, while soaking in all your detail, have to say that the copper linkage pins keep drawing my eye:anguished:... Bravo !
Thanks John.Wow Paul , say no more.:nerd::flushed::surprised:
Mick, Thanks mate hopefully more to come.Such a great start Scottie, love watching these builds
Ain't that so often the case. Iffy instructions with imprecise location points and then positioning of other parts is thrown out.This may be due to the dubious location of the bulkhead and dash board earlier.
