D
Deleted member 4557
Doors anyone sharpen their own blades ?
That's what I thought Si, just need someone to devise a jig that holds blades at thatI have had some success using wet and dry to re sharpen blades. Getting the angles right is crucial though
Thanks Tim, I guess your right but blades are so expensive and I still don't knowTo be absolutely honest Tony, the time taken, against the cost of new blades, is not cost effective in my opinion. In addition, you will never resharpen an old blade to as new condition unless you use an expensive bit of kit like a Tormek sharpener, and even then you might not be successful. There really are better uses of your time![]()
I did exactly the same Tim ! Have to agree with you on the blades too . The swann morton blades are cheap enough ( John sells them in the shop £2.49 for a 5 pack or about £17 for 100) and as you say , you could never sharpen a blade as well as they come from the factory ( unless youve made your own laser sharpening machine )Funnily enough I blunted and smoothed the curved blade in my hobby knife and now use it to apply filler.
I generally use Swann Morton scalpel blades as I agree they are the best.I normally add a couple of packs when I make up an order from the shop. I did get some knock offs ones from another supplier but they are poor by comparison.
As an aside as a lad I seem to remember seeing adverts in newspapers for pyramid shaped containers to keep razor blades in with the promise that they would stay sharp longer…. Do you think they worked
Geoff.
I remember that vaguely as well. Folded dollar bills wasn’t it?I generally use Swann Morton scalpel blades as I agree they are the best.I normally add a couple of packs when I make up an order from the shop. I did get some knock offs ones from another supplier but they are poor by comparison.
Geoff.
