You'll find out soon enough! Im looking forward to getting started on this :thumb2:Mark I’m hoping that is the case I’m sure it will be
Yeah I’ve built a few of these 1/48 Tamiya kit and really like themYou'll find out soon enough! Im looking forward to getting started on this :thumb2:
Closer that we're getting, the more 'nervous' I'm getting - the kit that I've picked has a lot of PE in it, and I've never even had a kit with it before!:confounded:
Will be reading up on the use of it and how to work with it, saw that one part has to be bent into a circle for the machine gun fitting round the hatch.:surprised:Just take it slowly and one step at a time!!
Gerry,Will be reading up on the use of it and how to work with it, saw that one part has to be bent into a circle for the machine gun fitting round the hatch.:surprised:
Probably should have gone with a T34 - have done tracks before, so wouldn't have to break fresh ground![]()
Will have a closer look at it later, other than it forming the ring, if I remember right, most of it makes the angle plates for the 'armour' and the ski fittings.Gerry,
trying new things & techniques is good! With PE, you just have to be methodical! and just because it's on the fret, doesn't mean you have to use it. I take the attitude, if it's too small to handle easily - forget it, also, does the part actually add anything to the model? Sometimes bits seem to be added to the fret, just to fill it up!
Ermmm, not right at the moment, thank you :surprised:Well Gerry maybe this will help. She has helped JR on may occasions. Anyone else before we begin?????
You’ve been there haven’t you PaulNooooooooooooo..........
I would just find something fractionally smaller than the circle to bend it round, I say smaller because I find the pe will spring open a tiny bit after.Will be reading up on the use of it and how to work with it, saw that one part has to be bent into a circle for the machine gun fitting round the hatch.:surprised:
Probably find you don't need half of it Gerry. I think most of the really small parts are there to just make up the sheet !Closer that we're getting, the more 'nervous' I'm getting - the kit that I've picked has a lot of PE in it, and I've never even had a kit with it before!:confounded:
Hang in there buddy , we'll get through this , Matron is arming herself up with the new multi purpose A10 Wart Hog derived injection system !I'm now back in JRs' ward as the multiple straight jackets were not effective in restraining me, and due to my 60s experience, pharma has unexpected results when administered, so as he's known as a calming influence on me, I'm back.
Ok gang just hours before we start is you glue and tools ready? Remember let’s have fun I’m sure we will this looks like a fair crowd. I appreciate everyone who has joined in. Thanks for making this happen.
