I've had this in the stash for a while ( I got it off John in a Trumpeter Sale........) and I've been pondering on how best to display it.
For it in action:
The easiest way would be in travel configuration, with the digging wheel raised, but I don't think that really cuts it. It really should be shown actually digging a trench.
The BTM-3 is based on a T-54 chassis, reversed, so the drive sprocket is at the front - the length is stated as 7.4m, although, I reckon that's with the wheel stowed. 3.2m wide. It can dig a trench 1.5m deep, by 1.0m wide.
In 1/35, that's 210+mm long,91mm wide, trench 43mm deep x 28 wide.
My doubts are about the size of the base - I reckon, it would have to be about 2.25 times the length of the Chassis = 470mm long. Wide, in order to take in the spoil thrown out on either side 3 times the width of the vehicle = 275mm, and the depth of 43mm +10mm= 53mm.
So, I have to have a base that is 470mm long x 275mm wide x 53mm deep, with a 43mm deep x 28mm wide slot running about 150mm in from one end.
Has anybody any thoughts on how to construct such a base, without major carpentry, or weight problems?
I've had several ideas, but none seen particularly feasible! This is quite the largest single vehicle base I've ever considered, definitely outside my comfort zone!!
For it in action:
