Spitfire Mk.Vb (Trumpeter 1/24)
Steven000
Steven
Belgium
Hi guys,
After finishing my Arctic Bf 109 I'd like to add an adversary - which will be a Spitfire Mk.Vb from Trumpeter (also in flight).
- Length 384.8mm (15,14")
- Wingspan 511.2mm (20.12")
This probably will be a very slow build (the 109 took 6 years lol), therefore I'm not putting it into the current "90 year of the Spitfire GB", although it will be nice joining you guys at the start of the GB. (y)
I have the Mk.VI (02413) in the stash - this is the same kit as the Mk.Vb (02403) with the addition of the pointy wingtips which I won't be using.
Sprue-shots - Wing...
Fuselage...
Tail, wheels, a bomb...
Engine...
Clear parts - and the pointy wingtips/prop I won't be using...
Rubber tires, steel rods and PE-hinges - 3 resin figures (won't be using them for this project)
Instructions, paint scheme (m.kVI), decals...
Looking forward to this build, thanks for watching & Cheers
Made a start on this one :coffee:
Cut and cleaned all parts for the first steps,
At the moment I have most of the cockpit and engine glued together, the engine won't be visible in flight but I need the propeller shaft.
The seat looks weird with the wooden panel? I'm working on a pilot so not much of the seat will be visible in the end.
Thanks for reading - Cheers
You have to love a 1/24 Spitfire. I did the Airfix one a few years ago and loved it. Happy building . I will be following along Steve
SO WILL I Steven so how long do you think this build will be ? as im getting old lol
chrisb
Thanks guys!
chrisb
Well I can only hope I'll finish it in your lifetime Chris 🙏😅 Please stay alive for at least another 6 years lol
I got me some metal 'Hispano 20mm cannons' which look much better than the kit parts - Also bought a 3D model of a pilot online, scaled him down from 1/6 to 1/24 and 3d printed him in resin (did some small changes to the head) - Took a while as it's a messy job but he came out great so far.
See you later, cheers
Just a small update on this,
Quite a lot of large injector marks inside the fuselage, not all of them are visible in the end though.
All the flight surfaces use the typical Trumpeter metal hinges, in the end I'll add some glue to make them static in place.
Added more small bits to the inside of the fuselage and engine - a few more sub-assemblies.
Trying to get all the parts ready for the fuselage glue-up so I can adjust the resin pilot to fit inside the cockpit.
Thanks for watching - Cheers :coffee:
Coming along nicely Steve. What is it with the wooden seat though? I thought all spits apart from the very early ones, had Bakelite seats? Is it a high altitude mod or something?
PS, keep this rate of progress up and you’ll easily make the 100 year tribute build date 😄
I think they referenced the seat from a museum or replica, as far as I understand it should be either aluminium or Bakelite indeed. Hope to get it finished a bit sooner lol 😅 cheers
Thanks 🙏 Still working a bit on this one 🔨
Test-fit of the resin pilot - I had to remove the foot pedals but further it looks ok,
Black primer, when spraying I noticed I forgot the door-hatch, so quickly had to glue it in and continued spraying,
Next I added an olive drab primer as some sort of dark base color,
Interior green mix and a highlight for the pilot. (for my own ref I used : 2x thinner - 1x 71.331 - 6x 71.305)
Trumpeter has this habit of making the instrument panel in clear plastic, but with holes where it should be 'clear' - So I added black primer and filled the holes with Micro kristal klear. Next I added a dry-brush and painted the white needles on the backside. There's a thin film inside the kit to put behind the gauges but with a closed canopy you won't see any of that.
I had a really hard time with the pilot, my paint dried to fast with the hot weather and I tried to rush things,
This morning I did some retouching and finished the pilot and cockpit. Still some ugly injector marks I forgot to remove...
The pilot was glued in place with superglue (gel)
Looking forward to close up the fuselage - Thanks for watching :coffee: Cheers
Great work steven , pilot looks excellent . I remember reading about the monumental cock up Trumpeter made with the seat - they measured up a museum exhibit that had the piece of wood temporarily fitted on the seat and reproduced it faithfully! :LOL:
Thanks guys 🙏
Just a quick update, all these parts have to go inside the fuselage in one glue-up,
All parts glued to one side, the other side ready to mount,
Took a while to get everything lined up but quite happy with the fit so far,
Still very hot inside the house 🥵
Cheers 🥤
