Stirling Glider Tug
Hi Richard, this is a most impressive build you have going on here mate. Great scratch- and paintwork!
Thanks Bros...Wouter and Paul. Glad to have you along for this old build.
Thanks Steve, I've been away down south in Singapore last weekend and have not done any bench time or been on the net. This is another one of those old builds that is being shown again. The engines would mostly be covered so strong contrast highlights helped bring out the detail when peering though the cowling.
Continuing the blog on the Stirling. I masked the many windows on the fuselage with white glue using a coctail stick for application. I let the glue flow slowly into the edges.
View attachment 304570 View attachment 304571 View attachment 304572 View attachment 304573
I forgot to show how I scribed panel lines with the help of a strip of dymo tape as a guide. Then dimples from the injection molding was filled with Tamiya putty after carefully masking the area with cello tape. This helps prevent detail from being sanded of whn sanding the putty.
View attachment 304574 View attachment 304575 View attachment 304576 View attachment 304577
Any raised plasting from the scribing or raised panel lines were sanded down. The many hundred revits were toned down by wet sanding as well.
View attachment 304578 View attachment 304579
Hi Richard, nice of you to show the techniques you use for things like scribing.
Sweet looking tow mechanism too.:thumb2:
Fernando
No problem Fernando...always willing to share as it's never rocket science or a trade secret.:smiling:
Continuation of the Stirling...it should be paint now...actually no as there is the little details to touch up and mask...
View attachment 307778 View attachment 307779 View attachment 307780 View attachment 307781
If anyone of you have built an old Airfix kit will know that not all their clear parts fit snuggly, dimples and thick parts are encountered. Proper masking and then filler added at the joints and smoothing out with fine sanding. Dimples filled and edges on thick parts shaved thin to give an optical illusion of a thinned panel for the undercarriage door.
View attachment 307782 View attachment 307783 View attachment 307784 View attachment 307785
Then pre-shading is done with a steady hand and sore index finger. Then a final burnish to the masking and plugging up any gaps before painting commences.
Next painting begins...
Nice to see the wet stuff going on. The build has been great fun to watch. Good luck with the airbrush:thumb2:
Just seen this one Richard, I don't know how I did miss it though, but glad I've seen it. Some great alterations going on, l'm watching from now on.
No worries Ian, I find this sight has a blind spot after 10 postings unless you are searching specifically on a subject or modeller that you prefer. Glad you found it...it has just a few posts more to the finish line then I'll start one on the Horsa glider.
D-Day stripes painted and masked with the dark earth layer applied leaving areas for the dark green to be sprayed...
View attachment 307951 View attachment 307952
Blue tac masking in rolls were stretched and contoured for the next color. All masks removed...
View attachment 307953 View attachment 307954
You can see the Horsa in the background
View attachment 307955 View attachment 307956
There was some paint lifting when the masks were removed so retouching was done. Just look at the heap of masking.
View attachment 307957 View attachment 307958
An impressive amount of extra work going on here, and the results speak for themselves.
Thanks Colin, I just wanted to see how far I could go with my old Airfix kits. Got a whole lot of them at a bargain price at a warehouse back when we thought we might never see them again. Now they're back...some with new tooling.:smiling4:
Sorry to read about the paint lifting, but a great paint job Richard.:smiling:
Nice work in keeping the pre-shade intact, in multi-colour camo I find it very hard to keep it intact but you've done it.:thumb2:
Nice Horsa too:hungry:
