Thanks Ole. Its an enamel and needs to go through the airbrush.
Andy
Andy
Cheers Colin. I couldnt find what they sent with the kit but i got just the thing in the work shop for the job.\ said:aha we have red stuff![]()
Looks very smooth Andy, just shows preparation is the important part eh?.
You've probably already got this sussed but a mate of mine who built boats quite a bit used to put some of those cheap felt sticky pads on the stand/cradle (whatever its called) when he tipped it up the right way to stop the paint being damaged or sticking to the stand/cradle if not fully cured for any reason.
He used to swear by them and said they were better than the rubber/soft plastic type pads you sometimes get issued with the boat kit.
Hi Andy, what paint did you use for the red? cheers Derek\ said:Thanks Derek. Im not sure what to use on a boat that is going in the water.Andy
Derek, the red is made by Spectra a specialist fuel proof paint for models, the black will be by Flair and again with the same proofing. It doesnt mention anything about requiring a varnish afterwards and does show a boat on the lable.\ said:Hi Andy, what paint did you use for the red? cheers Derek
Hi Andy, Not familiar with these paints I'm afraid, but as you say they are probably water resistant anyway. Cheers Derek\ said:Derek, the red is made by Spectra a specialist fuel proof paint for models, the black will be by Flair and again with the same proofing. It doesnt mention anything about requiring a varnish afterwards and does show a boat on the lable.Cheers
Andy
