A bit more progress.
I put in all the mortar between the stones and the bricks. A mix of fine sand (that kiln dried stuff used on block paving), plaster and some powdered grey pastel chalk was brushed in dry and then fixed with VMS Ballast Freeze. Took a lot of sessions as with the powder being brushed in dry I could only work on a horizontal surface otherwise it all feel out :rolling: The faded door was done with a grey and brown base and AK Worn Effects with a Vallejo blue top coat. The AK stuff works like hairspray but is much more controllable and consistent.
I added a layer of cork to the bas although it will all need texture and paint but the cork will make it easier to pin the figures in place.
So a rough idea of where we're heading, nothing is fixed yet. A fair bit more to go on the stall and the figures and jeep to add.
Thanks again for your kind posts and your patient support.
