A clean, tidy, clean and organised workbench. I always like to work in an organised way so it comes naturally to me but, even so, at times my bench does get a bit messy….
We all know the benefits of this but let’s list them anyway…
1/ You can find what you need quickly when you need it. How often have we searched around the bench ‘well that 0.6 drill bit was there two weeks ago, where has it gone?’
2/ Looking for that part you need, that 5 minutes ago you finished ‘deburring’. Not to mention the small part that pinged off the tweezers, now, is it somewhere on the bench or have I got to fight the carpet monster for it? With a clean organised bench it s a lot quicker to rule that out ready to put on the armour for the fight!
3/ Dust. If the workbench is tidy it is so easy to run around it with your handy desktop vacuum to pick up the dust from your sanding session or the offcuts from the clean up. Better the dust in the pan than getting on your model.
So yes there are a lot of reasons to clean and tidy up. Of course you need a place for everything and everything needs it’s place. Life is so much easier that way.
Now this is how I (try) to work…
I finish off working on the interior parts of my build, pulling together the sub-assemblies and getting it all ready for a painting session. I know that I will spend the next two or three sessions painting and weathering before I need to cut and sand again. So, a few seconds putting all the tools into their place, a quick run around the bench with the vacuum to get rid of sanding rubble and dust and sorting the ‘subs’ so I know what colour I am spraying on what. Easy peasy.
After spraying this is how my bench looks
To the very left you can see the sprues in their place then to the right, all lined up my little pots. The first has the decals cut off ready to add when the parts are painted, the next few pots have parts that are ready for weathering, grouped depending on what is needed. Also there are some parts too big for the pots that are also big enough not to be lost ….
Those pots are in frequent use (I have and use a dozen of them) throughout a build, no more scrabbling for that part you have just cut off the sprue, it’s safe in its pot with other parts from that stage in the instructions.
Above the centre section of my bench with, to the left all the sprayed parts ready to hand paint fine details over the base colour. To the right (top) of them my little hand vacuum sat there ready to quickly run over the bench, something I often do several times a session, picking up that pesky dust.
On the right side we see the instructions in a holder taking up a lot less valuable room than if they were flat out. They are not always tucked neatly inside, often the are just propped up on the front of the holder specially when I find myself flicking back and forward.
Next to that is my bit of paper on which I have written the colours with their codes from the instructions, a quick and easy reference to find out what colours ‘H’ or ‘A’ refers to.
After a couple more session I will be ready to pull those subs together then on to the next stage when sanding sticks and cutters once again take over the space.
Well that’s how I try to work. It does make life a lot easier but, of course, it does not always work out that way. Naturally lazy, cleaning up and keeping thing tidy actually saves me effort, but sometimes bad habits take over….
Over to you, what your ‘bench discipline’ like?
